Paragraph panel
I click on the double arrow symbol of the paragraph panel and I don't see any difference between the 3d and 4th click:
Works here, but each click narrows the panel.
https://recordit.co/I7vOR59NH5
@encart said in Paragraph panel:
I'm getting the same result as you here. All four clicks work but the panel reduces in width each time
registered the same thing, but thought that maybe it was
because of my new computer mouseyou can also see it in my video
@Boldline @encart @Subpath Thank you for testing this
When I launch VS, I get the complete panel with all options but when I cycle by clicking the double arrow, I get this issue... & indeed, the panel width decreases each time.Edit : no, I never get the complete panel... I've just checked with your videos.
@Pat Could be a settings or workspace issue.
I get here all 4 states correctly (but the size decreases, which could be a bug).Try starting with shift+alt+control to reset all options.
@VectorStyler Thanks but "shift+alt+control" doesn't reset options on my pc.
@Pat Try in Edit -> Preference Files -> Restore Default and View -> Workspace Files -> Restore Default
@VectorStyler Thanks, it works when I launch VS:
but once I click on the double arrow, I can't get the complete panel
Edit: to get it back I always need to restore Workspaces Files default
@Pat I opened a bug on this one and will try to figure out what happens.
@VectorStyler Thanks. I've tested on my two W11 pc & it is the same issue.
