    Paragraph panel
    12 Posts 5 Posters 9.2k Views 4 Watching
      encart
      Works here, but each click narrows the panel.
      https://recordit.co/I7vOR59NH5
      Windows 11 Home 10.0.22621
        Boldline @encart
        @encart said in Paragraph panel:
        I'm getting the same result as you here. All four clicks work but the panel reduces in width each time
          Subpath @encart
          registered the same thing, but thought that maybe it was
          because of my new computer mouse
          you can also see it in my video
          • B Offline
            B-Vs-V
            @Boldline @encart @Subpath Thank you for testing this ☺
            When I launch VS, I get the complete panel with all options but when I cycle by clicking the double arrow, I get this issue... & indeed, the panel width decreases each time.
            Edit : no, I never get the complete panel... I've just checked with your videos.
              VectorStyler @B-Vs-V
              @Pat Could be a settings or workspace issue.
              I get here all 4 states correctly (but the size decreases, which could be a bug).
              Try starting with shift+alt+control to reset all options.
              • B Offline
                B-Vs-V @VectorStyler
                @VectorStyler Thanks but "shift+alt+control" doesn't reset options on my pc.
                  @Pat Try in Edit -> Preference Files -> Restore Default and View -> Workspace Files -> Restore Default
                  • B Offline
                    @VectorStyler Thanks, it works when I launch VS:
                    but once I click on the double arrow, I can't get the complete panel
                    Edit: to get it back I always need to restore Workspaces Files default
                      @Pat I opened a bug on this one and will try to figure out what happens.
                      • B Offline
                        @VectorStyler Thanks. I've tested on my two W11 pc & it is the same issue.
