    Trim between two nodes
    24 Posts 6 Posters 35.9k Views 5 Watching
      Subpath @b77
      well for me where also enough to set that Triangle
      could highlight that segment in complementary color be a way ?
      • IgullI Offline
        Igull @Subpath
        @Subpath said in Trim between two nodes:
        could highlight that segment in complementary color a way ?
        TBH, that would be nice, but adds icing on the cake πŸ™‚ I'd be happy with leaving the triangle - knowing that I was about to hit delete and remove it all anyway πŸ™‚
        Neil
          Subpath @Igull
          @Igull
          you right, extended my post above
          to set that triangle alone would fit it for me
            b77 @Subpath
            @Subpath and @Igull
            It's OK with me to use just the triangle mark for both node placement and segment highlight.
            • IgullI Offline
              Igull @VectorStyler
              Is it possible to implement this feature, using the shape editor tool, click a segment and hit backspace/delete to delete that segment rather than delete the whole object ?
              TIA
              Neil
                VectorStyler @Igull
                @Igull said in Trim between two nodes:
                It is in the backlog.
                IgullI J BoldlineB 3 Replies Last reply Reply Quote 0
                • IgullI Offline
                  Igull @VectorStyler
                  @VectorStyler said in Trim between two nodes:
                  πŸ‘ πŸ‘
                  Neil
                  • J Offline
                    Jayanta Das @VectorStyler
                    @VectorStyler I was searching for the easiest way to delete segment and found this thread. There is a simple way to delete segment in AD with node tool holding CTRL and click will delete the segment.
                    Example in AD
                    Mac Mini M4 Pro | 24Gb
                    WIndows 11 | Intel i5 11Gen
                    Wacom Intuos Pro
                    VectorStylerV BoldlineB 2 Replies Last reply Reply Quote 1
                      VectorStyler @Jayanta Das
                      @Jayanta-Das It is in the backlog for 1.2
                        @Igull are you wanting the option to remove a segment entirely, leaving an open path?
                        If this gets implemented, would it take away the current "click a segment/node and hit backspace/delete to delete the node and click backspace/delete a second time to delete the whole object"?
                        I had advocated for this current option mentioned above and would like to be sure it's still an option in VS going forward as i use it quite often to quickly remove things
                          Boldline @Jayanta Das
                          @Jayanta-Das said in Trim between two nodes:
                          Example in AD
                          This looks like a great solution - glad it will be in 1.2!
                          • IgullI Offline
                            Igull @Boldline
                            @Boldline said in Trim between two nodes:
                            Yes, that's correct.
                            No, that would still stand - I also like the idea of hitting backspace/delete a second time to delete the complete object.
                            IIRC, in AI, selecting the segment then hitting delete, deletes the segment, but leaves the two adjacent nodes highlighted - hitting delete again would delete the complete object as it has both ends of it's vector selected.
                            Neil
