    Trim between two nodes
    24 Posts 6 Posters 35.9k Views 5 Watching
    • IgullI Offline
      Igull @b77
      @b77 said in Trim between two nodes:
      It's just that I thought highlighting the segment somehow would have been better.
      But I can't think of an elegant way to highlight the segment without making things look more busy than they already are when in node editing (with so many nodes and BΓ©zier handles).
      TBH, I just checked AI - it highlights the whole path (not wonderful really !) So, your idea of placing an X or as is, an arrow/triangle will work just fine I think ?
      That way, everything will remain the same for mode editing etc.
      Neil
        Subpath @b77
        well for me where also enough to set that Triangle
        could highlight that segment in complementary color be a way ?
        • IgullI Offline
          Igull @Subpath
          @Subpath said in Trim between two nodes:
          could highlight that segment in complementary color a way ?
          TBH, that would be nice, but adds icing on the cake πŸ™‚ I'd be happy with leaving the triangle - knowing that I was about to hit delete and remove it all anyway πŸ™‚
          Neil
            Subpath @Igull
            @Igull
            you right, extended my post above
            to set that triangle alone would fit it for me
              b77 @Subpath
              @Subpath and @Igull
              It's OK with me to use just the triangle mark for both node placement and segment highlight.
              • IgullI Offline
                Igull @VectorStyler
                Is it possible to implement this feature, using the shape editor tool, click a segment and hit backspace/delete to delete that segment rather than delete the whole object ?
                TIA
                Neil
                  VectorStyler @Igull
                  @Igull said in Trim between two nodes:
                  It is in the backlog.
                  IgullI J BoldlineB 3 Replies Last reply Reply Quote 0
                  • IgullI Offline
                    Igull @VectorStyler
                    @VectorStyler said in Trim between two nodes:
                    πŸ‘ πŸ‘
                    Neil
                    • J Offline
                      Jayanta Das @VectorStyler
                      @VectorStyler I was searching for the easiest way to delete segment and found this thread. There is a simple way to delete segment in AD with node tool holding CTRL and click will delete the segment.
                      Example in AD
                      Mac Mini M4 Pro | 24Gb
                      WIndows 11 | Intel i5 11Gen
                      Wacom Intuos Pro
                      VectorStylerV BoldlineB 2 Replies Last reply Reply Quote 1
                        VectorStyler @Jayanta Das
                        @Jayanta-Das It is in the backlog for 1.2
                          @Igull are you wanting the option to remove a segment entirely, leaving an open path?
                          If this gets implemented, would it take away the current "click a segment/node and hit backspace/delete to delete the node and click backspace/delete a second time to delete the whole object"?
                          I had advocated for this current option mentioned above and would like to be sure it's still an option in VS going forward as i use it quite often to quickly remove things
                            Boldline @Jayanta Das
                            @Jayanta-Das said in Trim between two nodes:
                            Example in AD
                            This looks like a great solution - glad it will be in 1.2!
                            • IgullI Offline
                              Igull @Boldline
                              @Boldline said in Trim between two nodes:
                              Yes, that's correct.
                              No, that would still stand - I also like the idea of hitting backspace/delete a second time to delete the complete object.
                              IIRC, in AI, selecting the segment then hitting delete, deletes the segment, but leaves the two adjacent nodes highlighted - hitting delete again would delete the complete object as it has both ends of it's vector selected.
                              Neil
