    Trim between two nodes
    24 Posts 6 Posters 35.9k Views 5 Watching
    • IgullI Offline
      Igull @b77
      @b77 said in Trim between two nodes:
      There is no way to click a segment to select it.
      Not sure a single click could mark a possible node location (as it currently does) AND also select that segment without confusing users?
      Using the Shape Editor tool, if you single click a segment, it leaves a stationary indicator "arrow" at that point, so VS must know that it is a segment as it has just marked it with the arrow ?
      All VS needs to do is NOT delete the whole path when backspace is hit, but only the segment - problem solved ๐Ÿ™‚
      Selecting a node and hitting backspace/delete whatever would still remain and not confusing at all. You would also still be able to double click to produce a node.
      Further, VS allows you to drag that segment to produce a curve (GREAT feature BTW !!!) - so it definitely knows it's a segment.
      In essence the only thing that needs to change is to not delete the whole path but only the segment (as I suspect the original intention was ๐Ÿ™‚ )
      Neil
        b77 @Igull
        @Igull I agree that the โŠณ node marking can work for what it now does (show the place where if you click the [+] key it will add a node) and also "mark" the clicked segment for deletion.
        It's just that I thought highlighting the segment somehow would have been better.
        But I can't think of an elegant way to highlight the segment without making things look more busy than they already are when in node editing (with so many nodes and Bรฉzier handles).
        IgullI S 2 Replies Last reply Reply Quote 0
        • IgullI Offline
          Igull @b77
          TBH, I just checked AI - it highlights the whole path (not wonderful really !) So, your idea of placing an X or as is, an arrow/triangle will work just fine I think ?
          That way, everything will remain the same for mode editing etc.
          Neil
            Subpath @b77
            well for me where also enough to set that Triangle
            could highlight that segment in complementary color be a way ?
            • IgullI Offline
              Igull @Subpath
              @Subpath said in Trim between two nodes:
              could highlight that segment in complementary color a way ?
              TBH, that would be nice, but adds icing on the cake ๐Ÿ™‚ I'd be happy with leaving the triangle - knowing that I was about to hit delete and remove it all anyway ๐Ÿ™‚
              Neil
                Subpath @Igull
                @Igull
                you right, extended my post above
                to set that triangle alone would fit it for me
                  b77 @Subpath
                  @Subpath and @Igull
                  It's OK with me to use just the triangle mark for both node placement and segment highlight.
                  • IgullI Offline
                    Igull @VectorStyler
                    Is it possible to implement this feature, using the shape editor tool, click a segment and hit backspace/delete to delete that segment rather than delete the whole object ?
                    TIA
                    Neil
                      VectorStyler @Igull
                      @Igull said in Trim between two nodes:
                      It is in the backlog.
                      IgullI J BoldlineB 3 Replies Last reply Reply Quote 0
                      • IgullI Offline
                        Igull @VectorStyler
                        @VectorStyler said in Trim between two nodes:
                        ๐Ÿ‘ ๐Ÿ‘
                        Neil
                        • J Offline
                          Jayanta Das @VectorStyler
                          @VectorStyler I was searching for the easiest way to delete segment and found this thread. There is a simple way to delete segment in AD with node tool holding CTRL and click will delete the segment.
                          Example in AD
                          Mac Mini M4 Pro | 24Gb
                          WIndows 11 | Intel i5 11Gen
                          Wacom Intuos Pro
                          VectorStylerV BoldlineB 2 Replies Last reply Reply Quote 1
                            VectorStyler @Jayanta Das
                            @Jayanta-Das It is in the backlog for 1.2
                              @Igull are you wanting the option to remove a segment entirely, leaving an open path?
                              If this gets implemented, would it take away the current "click a segment/node and hit backspace/delete to delete the node and click backspace/delete a second time to delete the whole object"?
                              I had advocated for this current option mentioned above and would like to be sure it's still an option in VS going forward as i use it quite often to quickly remove things
                                Boldline @Jayanta Das
                                @Jayanta-Das said in Trim between two nodes:
                                Example in AD
                                This looks like a great solution - glad it will be in 1.2!
                                • IgullI Offline
                                  Igull @Boldline
                                  @Boldline said in Trim between two nodes:
                                  Yes, that's correct.
                                  No, that would still stand - I also like the idea of hitting backspace/delete a second time to delete the complete object.
                                  IIRC, in AI, selecting the segment then hitting delete, deletes the segment, but leaves the two adjacent nodes highlighted - hitting delete again would delete the complete object as it has both ends of it's vector selected.
                                  Neil
