    where is the view / zoom option on the left panel
    17 Posts 6 Posters 12.7k Views 5 Watching
    • P Offline
      poljand
      Super
      thanks.
      VS is the BEST
      B.
        @VectorStyler said in where is the view / zoom option on the left panel:
        @poljand There are two zoom tool modes: area and scrubby.
        can be set in Preferences -> Document Editor -> Area Zoom Mode.
        Had a thought here - would it be possible to add a modifier to the zoom to temporarily switch it to the other zoom mode? I usually prefer the less controlled zoom, but occasionally I want to dial in the zoom area. What if the option key was used as a zoom mode modifier to do so?
        J VectorStylerV 2 Replies Last reply Reply Quote 0
        • J Offline
          Jayanta Das @Boldline
          @Boldline In affinity space+Ctrl (windows) temporarily switch to zoom. I find it very handy while using graphic tablet.
          Mac Mini M4 Pro | 24Gb
          WIndows 11 | Intel i5 11Gen
          Wacom Intuos Pro
          • J Offline
            Jayanta Das
            I just check it is also same in VS Spade + Ctrl for zoom.
            Wacom Intuos Pro
              Boldline @Jayanta Das
              @Jayanta-Das I was trying space+ctrl for zoom on mac in VS and it's not working for me. I have other non-VS things assigned to those keys. I'm sure the temporary option would be great - I appreciate you mentioning it. Now I just need to figure out how it works for me
              @VectorStyler would it make sense to have a second click of to "z" key take you back to the last tool used? much like the "a" key swaps between node editor tool and transform tool?
              I think when we do use the "z" key, the option to use a modifier to switch between zoom methods would
              also be really helpful. open to other ideas as well
                b77 @Jayanta Das
                @Jayanta-Das On the Mac it's Spacebar + Cmd, but it doesn't switch to Area Zoom like Boldline asked for.
                It's just temporary zoom with whatever method is enabled in Prefs > Document Editor (scrubby or area zoom).
                  @b77 said in where is the view / zoom option on the left panel:
                  Interesting - Although not related to my specific zoom request, I'm glad @Jayanta-Das brought this up. My issue was I was not pressing the spacebar first and that was making the difference.
                    @Boldline If you press Cmd first you get the Spotlight search bar of macOS, that's why Spacebar needs to be pressed first.
                      @Boldline said in where is the view / zoom option on the left panel:
                      I think this is already possible, but must be configured in the Modifiers section of Preferences.
                        I think the automatic tool on/off selection with shortcuts could be generalized for all tools.
                        I added this to the backlog.
                          this would be amazing!
