    where is the view / zoom option on the left panel
    17 Posts 6 Posters 12.7k Views 5 Watching
      in addition to the Zoom Tool maybe
      this menu is helpful as well
        b77 @poljand
        @poljand said:
        you have to get used to it because it works a bit differently than in other programs
        If you need area zoom, enable it in Preferences > Document Editor > Area Zoom Mode.
          VectorStyler @poljand
          @poljand There are two zoom tool modes: area and scrubby.
          can be set in Preferences -> Document Editor -> Area Zoom Mode.
          • P Offline
            poljand
            Super
            thanks.
            VS is the BEST
            B.
              @VectorStyler said in where is the view / zoom option on the left panel:
              Had a thought here - would it be possible to add a modifier to the zoom to temporarily switch it to the other zoom mode? I usually prefer the less controlled zoom, but occasionally I want to dial in the zoom area. What if the option key was used as a zoom mode modifier to do so?
              J VectorStylerV 2 Replies Last reply Reply Quote 0
              • J Offline
                Jayanta Das @Boldline
                @Boldline In affinity space+Ctrl (windows) temporarily switch to zoom. I find it very handy while using graphic tablet.
                Mac Mini M4 Pro | 24Gb
                WIndows 11 | Intel i5 11Gen
                Wacom Intuos Pro
                • J Offline
                  Jayanta Das
                  I just check it is also same in VS Spade + Ctrl for zoom.
                  Wacom Intuos Pro
                    Boldline @Jayanta Das
                    @Jayanta-Das I was trying space+ctrl for zoom on mac in VS and it's not working for me. I have other non-VS things assigned to those keys. I'm sure the temporary option would be great - I appreciate you mentioning it. Now I just need to figure out how it works for me
                    @VectorStyler would it make sense to have a second click of to "z" key take you back to the last tool used? much like the "a" key swaps between node editor tool and transform tool?
                    I think when we do use the "z" key, the option to use a modifier to switch between zoom methods would
                    also be really helpful. open to other ideas as well
                      b77 @Jayanta Das
                      @Jayanta-Das On the Mac it's Spacebar + Cmd, but it doesn't switch to Area Zoom like Boldline asked for.
                      It's just temporary zoom with whatever method is enabled in Prefs > Document Editor (scrubby or area zoom).
                        @b77 said in where is the view / zoom option on the left panel:
                        Interesting - Although not related to my specific zoom request, I'm glad @Jayanta-Das brought this up. My issue was I was not pressing the spacebar first and that was making the difference.
                          @Boldline If you press Cmd first you get the Spotlight search bar of macOS, that's why Spacebar needs to be pressed first.
                            @Boldline said in where is the view / zoom option on the left panel:
                            I think this is already possible, but must be configured in the Modifiers section of Preferences.
                              I think the automatic tool on/off selection with shortcuts could be generalized for all tools.
                              I added this to the backlog.
                                this would be amazing!
