    Draw tool sticky settings?
      @Dazmondo
      so select the Pencil Tool and press and hold the Command Key
      If you look in the Toolbar the Shape Editor Tool should be selected.
      Now keep holding the Command Key and select any other Stroke/
      Brush. Then release the Command key and draw with Pencil tool
      the stroke should now be in the Style of your last selected.
      Here another Video for you
      where the Shortcuts will be shown.
      Here the Video:
        @Dazmondo
        What you trying to do in your Pictures above
        would not work, as far as i know.
        You cant draw Brush Strokes with the Pencil Tool.
        And to draw Brush Strokes with the Pen Tool
        would only work if you do the following.
        Take a look at this Video:
          VectorStyler @Dazmondo
          @Dazmondo Question: should the Pencil tool be able to paint with vector brushes (as an option)?
          DazmondoD S 2 Replies Last reply Reply Quote 0
          • DazmondoD Offline
            Dazmondo @VectorStyler
            Thanks Subpath / b77 for the tips, I was originally (stupidly) concentrating using the combo with the pencil tool (which doesn't work on the Mac) but works with the brush tool.
            Managed to get there in the end and got the job finished0_1658213279043_Screen Grab 2022-07-19 at 7.47.27 am.png
            I'm sure with a little practice I could now motor through these types of jobs - also now using that nice little tip from Subpath for working with the pen tool by temporally pressing 'b' to select the brush tool then hitting 'p' to continue the path - works great --- Thanks everyone
              Subpath @Dazmondo
              @Dazmondo
              your welcome, always happy to help
              have to say that i am very impressed by your Design, wow 👍
              As a small note, because it struck me.
              The text "Steam Kittens" doesn't really follow a text on curve.
              But maybe that's intended.
                Subpath @VectorStyler
                would it not a little more helpful if we could use
                the Pen Tool direct also for Vector Brushes ?
                without the workaround a descriped above
                  VectorStyler @Subpath
                  S IngolfI 2 Replies Last reply Reply Quote 0
                    For me, the advantage of this is so much greater than any confusion about it.
                    As you can see, @dazmondo has a problem while he
                    likes using the Pen Tool
                    with Vector Brushes and can't do that. I know he could apply it later.
                    But direct editing would be so much more forward.
                    Here two Programs from old Times :), that have been using this for a long time.
                    I still like them and have copies installed. These are
                    "Creature House Expression" and "Expression Design."
                    In "Creature House Expression" it is called B-Spline, but
                    Expression Design uses the Pen Tool for Vector brushes.
                    Here a Video Example:
                      @Subpath Added this as an option to the backlog.
                        great !
                        I think this will put a smile on many faces 🙂
                        • DazmondoD Offline
                          Dazmondo
                          The Steam Kittens have requested a back print for the T-shirt featuring Keith (the steampunk kitten character featured on the front) so thought I'd have a crack using the method detailed in this post and glad to report it was far less bother to do the shading using the brushes I made and really easy to edit ---- did have a fair few times that I had to force quit when doing the top hat detail, but got there in the end --- Still need to add tour dates and a logo:
                          1_1658249855933_Screen Grab 2022-07-19 at 5.55.50 pm.png 0_1658249855932_Screen Grab 2022-07-19 at 5.56.46 pm.png
                          great !
                          Big smile here👍
                          S 1 Reply Last reply Reply Quote 5
                            Subpath @Dazmondo
                            @Dazmondo
                            Thats so insane, i am totaly floored by your design
                            WOW !!!
                              @Dazmondo Really impressive work! Thanks for sharing what you've figured out and the final result.
                              @Dazmondo @Subpath I'm going to have to go in and look more closely at what exactly is being discussed as a design tactic between the pencil, pen and brush tools - I think I understand in part but would be interested to check out more with it.
                              It sounds like you want to be able to use a repeating brush along a path but the brush tool does not give you the control over the path like a pencil tool or especially a pen tool could do. So instead of making the lines first and going back and giving them the brush style after, you want to be able to see it right away and faster using the keyboard shortcuts - draw a path with the pencil or pen tool - hold down command (ultimately be able to pull the style from another sample in the design) click "b" to get to brush and have it convert to the repeating pattern already set there....
                              I'll have to go back and try things out as at this point I'm not sure if there's more to it or I have the general concept down
                                Subpath @Boldline
                                There are actually two concepts here.
                                The first one
                                -- How to draw a vector brush with the Pen tool.
                                You can't do this directly and just go for it.
                                You have to draw a line with the Pen Tool.
                                Then select the your Brush and set then
                                the brush thickness.
                                Another way i found is the following:
                                Select "B" for the Brush tool.
                                Paint a short first piece of your path with the Brush tool.
                                (this short piece should stay selected)
                                Then switch to "P" for the Pen tool and now you can continue
                                and draw your vector brush with the Pen tool.
                                Here a Video Example for this case:
                                  Here the Second one
                                  -- Suppose you have four different strokes in your design.
                                  (different size and color)
                                  and you know that you will use them very often
                                  You could create styles or presets for them
                                  and select them when you need one of them
                                  -- or you could try it this way
                                  Create your four strokes in the style you're going to need
                                  and put all four strokes next to the canvas
                                  For simplicity, I'm only using the Pencil Tool
                                  (but this method also works with the Brush Tool)
                                  (but the Brush Tool normally doesn't take any color information,
                                  Pencil Tool do)
                                  Now press "P" for the Pencil Tool
                                  move the mouse pointer over the area where your strokes are located
                                  hold the command key (Mac) / CTRL key (PC) and select
                                  one of the four strokes you want to draw with
                                  As you may know VS draws always in the style of the last selected
                                  object/stroke
                                  Therefore, when you draw, you draw now with that style.
                                  I think this is an easy way to quickly switch between
                                  different strokes
                                  Here is an example video (with recorded shortcuts):
                                  • DazmondoD Offline
                                    Dazmondo @Subpath
                                    Here the Second one
                                    Pencil Tool do)
                                    object/stroke
                                    different strokes
                                    Great way of starting off a job! --- I'd like to steal that for my workflow, if you don't mind ----- I've already set up the main brushes on the page I use for all the Steam Kittens illustrations I'll just copy paste my set brushstrokes into the next job artboard and away we go 👍 👍 👍 0_1658305858088_Screen Grab 2022-07-20 at 9.29.43 am.png
                                      @Dazmondo
                                      ... I'd like to steal that for my workflow, if you don't mind ...
                                      Of course I don't mind 🙂
                                      After all, I show these tips here to share ideas and tips.
                                      But remember, in your case, your illustration is
                                      is only black and white, it's easy.
                                      (this method doesn't take the color by Brushes).
                                      You can of course colorize your vector brush by
                                      choosing a color from a palette
                                      I myself found this method in the two vector programs mentioned above,
                                      "Creature House Expression" and "Expression Design".
                                      There you can select a brush directly with the Brush Tool and continue
                                      painting in its style (in the post above I show the programs in a video).
                                        @Dazmondo
                                        Must say it again, i really like your way of creating
                                        hatchings with Brushes (really cool idea !!!!)
                                        • DazmondoD Offline
                                          Dazmondo
                                          Thanks Boldline & Subpath👍
                                          Just been messing around with repeater and I'm blown away with what can be achieved now I've got my head around it -- for dot halftones it's ACE --- initially when I first used it, I found it would slow to a crawl and just thought it was for making fills similar to the pattern fill tool, and had no idea how well it works on raster art or photos even gradient meshes or when using raster effects on vectors - once expanded and unified this is great for t-shirts --- I know Boldline does a lot of t-shirt work and has probably mastered the repeater, but had no idea how powerful this is - this is now part of my workflow for this kind of stuff rather than using Clip Studio Paint / VectorRaster /or the halftone options built into Image Vectorizer ------ACE
                                            Ingolf @VectorStyler
                                            It's a bad, bad, bad idea to mix the two!!!! For this reason and many other reasons. It is an absolutely bad idea. And a pen tool is a science in itself with lots of complexity - more than you think. It should be kept completely isolated from other tools. It is a discipline unto itself and a tool unto itself.
                                            I strongly recommend that instead you can easily switch between pen and brush visibly, easily and intuitively without the two ever getting mixed up.
                                            Just as easy as switching between black and white color in fill and stroke with X in Photoshop. One press of a key - or an icon in the context bar.
                                            b77B S 2 Replies Last reply Reply Quote 2
