Right Click after selecting objects
When I right click after selecting the objects, the other object got deselect.
Recording
No problem here, everything remains selected as it should
(win 10 and VS 1.1.042)
@Subpath Doesn't work here in Win 11
Yes, saw it in your video. Very mysterious.
@Jayanta-Das I had simillar problems and reported them already. Now I can't reproduce it. You coud try to draw 3 objects, select them all and click with right button one of them. Probably only the clicked one will be selected. It looks like we are dealing with two selections. When you open the context menu, the inicial selection disappears and at the same time a new one is created only for the selected object.
What happens when you select some objects and try to open the context menu by clicking on an empty space? Selection disappears?
@Jayanta-Das Is the same happening with a mouse and also when using the tablet?
@encart I did as you said see the recording.
Yes, when I select some objects and try to open the context menu by clicking on an empty space selection disappears.
@b77 It is happening with all mouse, tablet and Laptop touchpad.
@Jayanta-Das
https://www.vectorstyler.com/forum/topic/2073/right-click-removes-the-selection-multiple-items-highlighted-in-the-context-menu/4
There is a regression with right click on objects and this will be fixed.
@Jayanta-Das This problem should be fixed in 1.1.048
