    Default built-in 3D Stars?
    23 Posts 6 Posters 37.7k Views 5 Watching
      Subpath @Boldline
      @Boldline , your welcome
      By the way, I'm also an advocate of something like this.
      I have also already pleaded for a section for polygons.
      Sections for Polygons
        Boldline @Subpath
        @Subpath yes there could be some other ways to incorporate that 3D feel into other shapes like the polygons.
          encart
          The first idea that came to my mind to create such a star quickly and accurately looks like this. The first one shows an example from AI, because only there I managed to do it as planned.
          https://recordit.co/OepFHuqCQL
          Unfortunately, in VS, I was unable to successfully apply the shape tool.
          https://recordit.co/SKiNQcv8HQ
          For me in this case it would be natural:
          • Draw a star
          • Draw cutting lines
          • Select everything and cut into pieces with a boolean operation
          But as I mentioned in another topic, the functions that do this expand the paths and thus there is space in between. Additionally, in the case of concave angles, the lines should have caps. Otherwise there is a problem like here.
          I wanted to use a knife for this, but snapping is not working for that tool. Hence, there is a lack of accuracy.
          If there is any proven method for precise cutting I will be grateful. Even on this example.
          VectorStylerV S 3 Replies Last reply Reply Quote 3
            VectorStyler @encart
            @encart Added the shape builder issues to the backlog as a bug.
              Subpath @encart
              @encart
              As I watched your video, I remembered a way I found
              out a while ago while experimenting with VS.
              Works similar to yours. But I create the lines
              using the "Square Star" tool. When I do it
              this way, the "Shape Builder" Tool also works.
              ( maybe the lines have to overlap ? )
              Here a Video this way
              Section Lines with Square Star Tool
                @encart said in Default built-in 3D Stars?:
                If there is a file which could be used to replicate this issue, please send it to me by email. Thanks!
                  encart @VectorStyler
                  @vectoradmin I sent you the file. Recreated but same result as before.
                  https://recordit.co/4GDGsdxMus
                  @Subpath Tried with overlapping lines, but same result. Works better when lines are expanded and merged into one shape. Imo these problems may be caused by center point.
                  https://recordit.co/IUWXtbxh7U
                  Edit:
                  Another way to make it: https://recordit.co/z3VzXOVjkn
                    If i convert the modified "Square Shape" to curve,
                    the result will be one Shape. Maybe thats why it works.
                    Video1
                    It also works when I drag Line through the Star
                    and copy and rotate the Line
                    Video2
                      VectorStyler @Subpath
                      @Subpath The last build contains some improvements to the shape builder tool working with open paths (and lines).
                      Using similar steps as @Subpath , but with Snap to Point and the Shape Builder tool: https://recordit.co/WjViOwpZid
                        Subpath @VectorStyler
                        cool, great 👍
                        that offers possibilties for other Projects too 🙂
                          encart
                          Still have problems on Win10.
                          https://recordit.co/FDXtnHutP3
                            @encart Send me the file, where the shape builder is not working.
                              no problem so far, is working
                              also under Win 10
                              But at the very first point there is
                              no snap and no snap indicator
                              ( little red circle )
                              Edited:
                              The peak of the ShapeBuilder results and the resulting oversize
                              was, as @Jayanta-Das wrote, because of the stroke applied to
                              the outside of the shape
                              Video: see here
                              • J Offline
                                Jayanta Das @Subpath
                                @Subpath Confirm no issue in Windows 11.
                                I think the oversized is due to the stroke applied to the outside of the shape.
                                Mac Mini M4 Pro | 24Gb
                                WIndows 11 | Intel i5 11Gen
                                Wacom Intuos Pro
                                  Subpath @Jayanta Das
                                  @Jayanta-Das
                                  ...I think the oversized is due to the stroke applied to the outside of the shape...
                                  yes, your right
                                  was probably in sleep mode 😴
                                  Did not realize it
                                  But the very first point did not snap
                                  • J Offline
                                    @Subpath
                                    Yes, didnot snap here also.
                                    Wacom Intuos Pro
                                    • Victor VectorV Offline
                                      Victor Vector @VectorStyler
                                      @VectorStyler said in Default built-in 3D Stars?:
                                      When creating shapes with Shape builder, you may want to check the size at which you create the objects. I was having difficulty creating those triquetra knots and the shape builder was giving me some difficulties. If the shapes were too small, so if the artboard was a letter-sized paper, 8.5"x11" (22 cm x 36 cm ), difficulties were happening when the shapes were smaller than about 2" x 2" (5 cm x 5 cm).
                                      Making the shape about 50% of the page size or bigger solved the problems for me. So you may want to investigate how scale affects shape builder, @VectorStyler, @encart.
                                      S VectorStylerV 2 Replies Last reply Reply Quote 2
                                        Subpath @Victor Vector
                                        @Victor-Vector
                                        interesting
                                          VectorStyler @Victor Vector
                                          @Victor-Vector said in Default built-in 3D Stars?:
                                          Will try to replicate at different size. But yes, size may affect the shape builder (and combine operations), as it affects the precision.
                                          If you have an example with the start+lines where the shape builder fails, please send it to me.
