    • Context menu/submenu presentation issue
      • syllie
      5576
      Thanks - That works now as expected and I can see all options offered.
      Bend distortion seems broken
      • postdes
      4774
      @postdes Moving the center point of the bend shape editor should work in the new build.
      Shape menu text is cut off
      • postdes
      5136
      @postdes This layout issue occurred when opening the shape view first time in El Capitan to High Sierra versions. The issue is fixed in the new build.
    • Pen tool - delete last segment
      • syllie
      10333
      @vectoradmin Jeez - so sorry about that. It was quite late over here and apparently I had an absolute dumb moment. It is all working as expected! Thanks for the fix!
    • indicators still disappear after a certain amount of time
      11020
      I am glad you found a cause, as this bug makes working in VS rather imporssible atm.
      Palette content scrolls too fast
      • statestreet
      8467
      @statestreet Only the color palette scrolling speed was changed. I will review the other lists also.
      Dragging blend into mask shape causes blend to disappear, breaks undo
      • statestreet
      7099
      Both the crash and the broken blend are fixed in build v1.0.013 RC1
      Three-point circle tool creates duplicate objects
      • statestreet
      4663
      @statestreet This issue is fixed in build v1.0.013 RC1
    • Pen tool line breaks when holding shift in mid-use
      6513
      @syllie @vectoradmin There's always the danger of wanting something to be too much like illustrator, or affinity, or corel, etc... We don't want to just do it like them for the sake of keeping things the same. We want innovation and new ideas to make their way in. I like the concept of being able to break a line like that with a keystroke, but I think it needs to be one not automatically associated with another more commonly used feature. Certain keys are just always going to be muscle memory use - control-v, control-c, z, shift... they've established themselves as consistent over countless software apps.
    • Reset Default Workspace - Win10 build 209
      • syllie
      5697
      @vectoradmin All good for Win10 - works as expected now.
    • Sections of work disappear, pen tool still having the restart issue
      14213
      The pen tool behaviour is much improved. The experience in itself is much smoother and this definitely looks like a step forward.
    • Constantly refreshing pointer (Win10)=
      5882
      Excellent - fixed in 210!
    • Magnetic close of a path seems to not work now - unless I missed a new setting
      4730
      @vectoradmin this worked again when I made a new document
    • Gradient tool - bug and usability suggestions
      4606
      Gradient tool looks so much better now - and is easier to understand.
    • Fill colour selection, quality of mouse pointers, squashed menu text - Win10
      • syllie
      4363
      Just checked out build 209 and I can see the fixes and improvements there. Thank you! The menu reads perfect now and the palette bar does what it should do. I think the crispness of the pointers can be improved further but they are much better now. I like the new application icon too!
    • Source jpeg that is locked shakes when traced over
      3666
      @Boldline There is some minor image positioning issue, opened a bug on this one.
    • D
      Two panels instead of one
      • danegeld
      3584
      @danegeld I added this issue to the backlog as a bug
      Problems with preview of installed fonts
      • Petar_MK
      4901
      @Petar_MK Font preview can be disable in Preferences -> Text Display section with Preview Fonts in Menu for the menu, and Preview Fonts in Lists for other font lists. It would be nice to have a quick video to see what is going on.
    • Layers > Object Options Opacity Slider Preview
      • badcat
      3353
    • New document - click and drag tab results in crash
      5459
      @vectoradmin said in New document - click and drag tab results in crash: @vectoradmin This issue is fixed in build 208 Indeed fixed, thanks.
