    • Could we reduce magnetic strength in half?
      2122
      @Boldline Will do so!
      Moving clipped objects changes their shape
      2737
      @VectorStyler File sent.
      Stroke mitre/overlap question
      • greenbeetle
      4351
      Success. Excellent, thanks.
      Object with two strokes, how to convert to curves ?
      3002
      @Pat Edit the stroke attributes or the shape? The stroke attributes can be edited in the Appearance panel: The shape cannot be edited separately. For that we instead should use the Offset Path live shape effect, and then convert to curves.
    • Transform Pivot Point Snapping
      3406
      @Igull said in Transform Pivot Point Snapping: I wonder if there is a preference on this that I might be missing No preference for this. I will try to find out what is the issue.
    • Distribute/Align Shapes Help
      7036
      Object Style Preset
      4525
      @VectorStyler Yes its fill was set to zero, thats the effect I wanted. As I said after saving as preset I had tested the preset by applying to other shape and it was working ok.
    • Increasing the range of keyboard shortcuts by adding more keys
      4715
      Suggest looking to WordStar for inspiration.
      New document setup - Why duplicates of the same data/parameters?
      4227
      @VectorStyler Well, I understand. In this case, why not remove the redundancies in the "Artboard options" window? It can be confusing to have all these different ways of changing/adjusting the same parameters whatever they are. It's not an issue, but at the beginning you always wonder if they are exactly the same settings.
    • does it make sense to have a zero width path brush stroke?
      2290
      does it make sense to have a zero width path brush stroke? No, not really, but there needs to be a lower limit.
      Why can't I permanently change the colour panel to "RGB sliders"?
      4596
      @VectorStyler I will finish a drawing and I'll send you the file. You can then test colour gradient changes with the "undo" function.
      Pattern brush.. Help
      3732
      @VectorStyler sent
      How to improve VS performance ?
      4783
      @Pat There is no reason for the slowdown, other than a possible bug with some effect or gradient type. If you send me that document I will try to replicate this.
      Editing a gradient colour
      8812
      @Jayanta-Das I will try to replicate this issue.
      Paste --> Paste in place -... : why in "Placing"?
      2717
      @VectorStyler Ok but why not create a submenu in "Paste" for all "Paste..." instead of having it in "Placing", it's just that I expect to find all the "Paste 'something' " in the same submenu of the "Paste" menu... not a big deal anyway.
      Testing Create adjustment layer: some effects apply to all objects (not only the selected one)
      7256
      I'm not sure, but I think the adjustment layers with effects is not a feature of other vector apps, but it does exist in Photoshop. It's awesome that we have adjustment layers in a vector graphics app.
      After Boolean Intersect, no more objects
      3962
      @VectorStyler In fact, "intersection" works if I merge the two letters first. I can't keep them separated in two distinct layers. Nice !
      Blending: how to get a specific path & not another ?
      5308
      @Pat Like your "VS" too very creative
    • Could/should the path stroke width be displayed when the path is selected with the node editing tool?
      2114
      @Boldline In the context panel? I think it could be displayed. EDIT: but then there are the other attributes, like color, etc.
      Curve/line & "break apart"
      2081
