    Small but annoying issue :-)
    8 Posts 4 Posters 6.8k Views 3 Watching
    • IgullI Offline
      Igull
      When doing a save as from VS, can it be arranged that only the filename - but not including the extension is highlighted - that way, I can simply type in the new filename without having to (annoyingly 🙂 ) re-type the vstyler extension. A really small thing, but just so helpful for lazy engineers like me 🙂
      FWIW, the last time I opened AI was about three weeks ago (?) - can't believe that - just so I could open a dxf file someone sent me. Now, if VS could only open/save DXF, that would mean that I might not need to open AI at all 🙂
      TIA
      Neil
      b77B VectorStylerV 3 Replies Last reply Reply Quote 0
      • b77B Offline
        b77 @Igull
        @Igull This happens only on Catalina and some other macOS versions, but here on Monterey (and Big Sur, IIRC) only the file name is selected.
        But I would ignore that and just type the name without adding the '.vstyler' extension, and the app adds it automatically.
        BoldlineB IgullI 2 Replies Last reply Reply Quote 0
        • b77B Offline
          b77 @Igull
          @Igull Btw, have you tried any of the DXF-to-SVG or DXF-to-PDF online converters like the one at https://cloudconvert.com/svg-to-dxf ?
          Are these worse, same or better than the AI internal converter?
            Tagging on to this topic - the ability to paste text copied to the clipboard into the save-as dialog box would be terrific
              Boldline @b77
              @b77 said in Small but annoying issue 🙂:
              I had not tried this, but it's good to know- thanks!
                VectorStyler @Igull
                @Igull I added this to the backlog: if not present, a ".vstyler" is appended automatically.
                  @Boldline said in Small but annoying issue 🙂:
                  Yes, this is a problem that has been reported before.
                  On some MacOS version, pasting will not work in the save panel.
                  I have this issue open, and will try to fix it, but found no solution so far.
                  • IgullI Offline
                    Igull @b77
                    LOL, now why wasn't that my first consideration 🙂 🙂
                    I just assumed that it wouldn't parse that, patently it does 🙂
                    Thanks for that.
                    Neil
