• Can I create tables in VectorStyler?
    @Kumr gladly
  • Transform Selection Node rotate along with the shape
    @Ayo said in Transform Selection Node rotate along with the shape: Shouldn't the Transform Selection Node (when using a rectangle) rotate along with the shape? I will try to add this.
  • VS Presets vs Styles
    @Ayo said in VS Presets vs Styles: If exported, does this become a preset? Both possible: It is still a style (when exported into a separate file) but can only be used if imported to another document. In the "Styles -> Document Styles" -> Options button there is Export to Presets to export styles to presets.
  • Turn off measurement readout
    @VectorStyler Thank you. I'm aware of the method to use spacing in the Alignment panel for positioning. However, it would be faster and more flexible in this case. Some improvements are needed on the Alignment panel to make it easier to use. I'll take some time to record.
  • Aspect Ratio locked
    @VectorStyler said in Aspect Ratio locked: Settings -> Editing -> Proportional Object Scaling That was the cause. Hit in my search for stroke scaling.
  • Tiny Square
    @Ayo said in Tiny Square: clicking beside object to clear In drawing mode, do not use click to clear selection, that will open the shape options view to create a new shape. Use the Esc key for selection clearing.
  • Partially responsive icons in side tool bar
    @b77 Thanks for the suggestion
  • What does 'Show Eraser/Knife/Brush Shape' setting do?
    @VectorStyler Naming that better describes the content would be desirable here? Could you say this? Show Eraser Shape > Preview Eraser Shape Smoothing Show Knife Shape > Preview Knife Shape Smoothing
  • Create guidelines
    @VectorStyler thanks
  • Paragraph Leading
    @VectorStyler Thanks. Similar leading options s are available in the character but not in paragraph panel (% value only). Changing leading value in character panel is not updating with converted values to the method used under paragraph panel or vice versa. [image: 1699172620848-screenshot-2023-11-05-at-1.53.08-pm-resized.png]
  • SVG Export Issues
    @chuckl Replicated the issue. What happens is that Layers with a single object are "expanded" into the object. This will not be done in the next build.
  • Min Max Leading
    @Ayo Limits the leading to a min/max value, regardless of XHeight or other leading options. There are some issues when setting the value (same bug as other text formatting issues). Fix will be in the next build.
  • Clear all content from the object?
    21
    28k Views
    @VectorStyler said in Clear all content from the object?: Clear Content should clear all content from the object Was wondering if Clear Content isn't the same as Clear object Style.
  • Purpose Extra Line Spacing in Paragraph Panel
    @Ayo I opened a bug on this one and will try to replicate it.
  • Offsetpath tool - corners
    @VectorStyler Thanks for the quick reply and help.
  • Color Palettes opacity setting confusion
    @VectorStyler Crossing messages. Thanks for your reply to (/forum/topic/3679/what-does-adjust-style-opacity-do). I'm starting to get a picture together with this. Nevertheless, very confusing, impure and incorrect in my opinion. Glad I can turn off the Palette Tools.
  • What does "Adjust Style Opacity" do?
    @Ayo said in What does "Adjust Style Opacity" do?: Adjust Style Opacity When enabled, the opacity value of the Color panel is set for the "fill" or "stroke" of the selected object. When disabled, the opacity value is set for the object.
  • How to set 'My Snapping Preset' as default
    @Ayo The current snapping settings should be the default for a new document (unless opened from a template). If other than the current settings are needed as defaults, then the only solution is to use a document template. The default document template for new documents can be changed in Settings -> Document Files -> New Template
  • Shape Builder or Paint Tool integral approach
    @Ayo said in Shape Builder or Paint Tool integral approach: Here you see the miracle happen: https://recordit.co/0bc8r77OyW Got it!
  • Why do I lose my text and text frame?
    @Ayo Yes, there was a mixup with text duplication. The fix will be in the next build. The text can be reassigned from the Links panel, by double clicking on the text item.
