• The shape rotates arbitrarily with transform panel
    @VectorStyler The turning knob is determined by the order of tool selections. I've mailed the workspace data to VS-support separately [image: shape-rotate-arbitrarily-2.gif]
  • Blending & Image effect
    @VectorStyler A crash occurred during testing, and finally, the steps to reproduce the crash were identified. 0_1720112738118_Blend Crash.vstyler https://youtu.be/ZaajOxtZMIE
  • Export PDF Artboards, how to get rid of the free canvas?
    @Ayo This is a regression from the last build, one artboard was added into the canvas category, which was not needed. It is fixed and the fix will be in the next build
  • Image import jaggy woes
    @debraspicher said in Image import jaggy woes: Pixel Preview isn't looking quite right either, whether it's 100% or not: I will look into this.
  • How to keep layer contents buildup when duplicating artboard
    @Ayo A fix will be in the next build, it will affect the move tool only (for now). Copy paste has different options (similar to AI).
  • Export Artboard to PNG with a bleed?
    I did have to work around this for printing off an illustration. Printing off the bleed would've been more straightforward, but the nice thing about being able to export a whole Canvas, is even though I have a lot of white space in the end, I was able to crop it down in PS, I could still get a bleed. In this case, I was printing to media that wasn't quite the original document size, so having that extra information in the bleed gave me some extra room to chop around the main art area: [image: 1719593774504-37f43669-0d55-4ccb-b0a1-6ea8ad6c8d44-image.png] Just thought I would share this for informational purposes.
  • Tiny transform dot – what is the purpose?
    @Raaskot Something is shown at the wrong position when rotated (supposed to be at the center). I will fix this.
  • Double click selecting shape text
    @Ayo Beeped too early. Must have been a hiccup. After restart it works again.
  • Faster way to do this? Simple drag & drop
    @debraspicher In the Layers panel options (panel menu -> Panel Options) enable the "Object Pasteboard" option to copy paste.
  • Mesh Gradients as styles
    @Kumr said in Mesh Gradients as styles: AI displays the following message when I open PDF (VS exported) and opens the mesh gradients as image objects. I will try to find out what can cause this.
  • File>Export one pixel less
    @debraspicher I will try to replicate this. Could be some rounding error
  • Layer bar signaling
    @Ayo said in Layer bar signaling: move (drag & drop) artboard selected object(s) from one layer to another without unfolding and digging into stacks I will look into if this can be brought forward from the features list.
  • Poor copy operation speed
    @VectorStyler That method is effective. After experimenting for a long time, this setting is the most perfect, and it can also be copied to the AI software [image: 1719141195977-mmexport1719140962505-resized.png]
    @debraspicher I will try to find a solution for this.
  • Troubles with Layer Creation, Layer naming (on creation)
    @debraspicher I will try to improve this (fixing the bugs first).
  • Was erase mode removed from the pen tool?
    @Boldline It is in the Pencil tool, but before starting to draw, check the "Eraser" option in the context panel.
  • Failing to edit colour stop on gradient with more than two colour stops
    @William-Kansepa said in Failing to edit colour stop on gradient with more than two colour stops: Settings>Editing>Collapsed Gradient Knobs I will try to replicate with this, and improve if possible.
  • Path Sketch unexpected result
    @Subpath said in Path Sketch unexpected result: @Boldline, @VectorStyler I have no problem if @VectorStyler just improves the path sketch tool. And I can live without a modifier key. That was just a thought that went through my head. I appreciate your idea
  • Open path shows filled color.
    @Boldline Case 1: A graphic filled with color, when splitting the nodes, the situation mentioned above will be obtained. Case 2: Importing a third-party file, it is not smooth, with many nodes, whether the path is closed is unknown, and it is easy to cause misguidance.
  • Shape text leading does not work properly
    @Li-Xiao Solved, thanks
