• Misbebavior ? When i inserting a Node
    @VectorStyler as far as i know, Node inserting follows the direction of the black arrows (see Picture) if you inserting nodes by double click on a Node so the node my red arrow is pointing at should not insert a node at all, or am I wrong? [image: 1652898550168-inserting-nodes.png]
  • Dont understand a behavior when deleting a Node
    @Subpath This looks like a regression (bug). Will be fixed ASAP
  • What causes this node handle behavior and how do I best utilize it?
    @VectorStyler said in What causes this node handle behavior and how do I best utilize it?: Changing the node type (just after the selected handle) to Cusp should fix this issue. yes that worked - thank you. This reminds me a little of the feature you added a few months back that involved using the spacebar to change the properties of node behavior. Is that still within VS? If so, is it in the documentation?
  • How to create letters made of circles?
    @Victor-Vector Its great how many ways VS offer to solve something like this
  • Default path brush size - too large?
  • Keyboard shortcut for word spacing between characters
    18k Views
    @VectorStyler sorry for the confusion. @b77 thanks for helping get that sorted out.
  • Keyboard shortcuts explanation "Em space" and "En Space"
    @b77 Added this to the backlog.
  • Rome-Kana conversion key
    @VectorStyler Thanks. I'm glad it was a bug and not a reduction in Japanese language functionality. Please fix this as soon as possible. It seems it's been like that since ver 1.1.xx. I didn't notice it either, as I've been away from VS for a bit. I feel a little sad that there are not many Asian users.
  • A question from a newbie.
    @FanVidder What I described is a pretty specialized area, so you won't find tutorials for it. Anyway, don't forget to: create artboards that match the UPM (in Glyphs it's 1000 by default, so make the artboards 1000pt tall); drag guidelines at least for the baseline (default is at 200pt) and for the ascent line (default is at 900pt). Btw, there are a few VectorStyler instructional videos here: https://vimeo.com/user95036806
  • Repeat secondary shape using first shape rotational center point
    @b77 I'll give it a try thanks!
  • How to modify a mask
    @VectorStyler: great, thanks
  • Strange behavior of multiple lines of Shape Text
    @Boldline said in Strange behavior of multiple lines of Shape Text: what if selecting multiple lines of text allowed for adjusting several lines at the same time? Almost exists, does not work well for open path baselines. Will be fixed in the next build. The feature is to select "Expand Path" in the Multiline drop down (Lines tab) of the text on path options.
  • Scaling image effects.
    @vectoradmin said in Scaling image effects.: Should it be inherited by member objects in a group? from my point of view yes. It would save me a lot of clicking . But that's just my opinion.
  • Why large triangles
    @b77 said in Why these arrows: @Ingolf It looks like 'Selection Outline Node' is set to 'Large Triangle' in Preferences > Indicator Shapes. The default is 'Small Rectangle'. You are right, thanks!
  • Moving cusp nodes + pressing control key
    @Boldline I said โ€œnot that practicalโ€. But youโ€™re right, I might be missing some cool possibility. If you find some cool use for it, please record a short video, Iโ€™m interested.
  • Node and handle color editor in preferences - did it get moved?
    @Boldline it got moved to Editing Options 1, but it resulted in a regression, will be fixed as soon as possible.
  • How to create this 3D effect in VS
    @MajorTom I can only agree with what Victor Vector said. Great Result.
  • How do we use the current version of the Anchor Point tool?
    @vectoradmin Gave it a try in Win 11 on VS 1.1.037 Had glitches too. File attached. 0_1651248685865_Anchor Point Tool issue.vstyler
    @Boldline Not possible to customize at this time. I will think of a suitable solution.
  • Snapping options
    @Devil-Dinosaur said in Snapping options: Is it possible to have something like : if you move up/down with shift it will snap the (almost) same level point of the same object. Same for shift + right/left ? @Devil-Dinosaur Added this to the backlog.
