Printer mark does not work properly (continued)
I will (gradually) move some of the fixed bug reports and implemented features to their respective subgroup.
They will still be accessible, and if the issue must be reopened, just post a new one with a link to the old one.Some additions will be made due to the above.
The basic functions seem to have been fixed.
As I mentioned in the previous post, it's better to fix the line widths of the marks.
Improvement: Each of the following should be set to 0.09mm.
-Crop:0.18mm <- too thick
-Bleed:0.18mm <- too thick
-Resistration:0.02mm <- Too thinIn the printing process after prepress, more necessary information is added to the Artboard by a special machine. These include more elaborate markers, process control checks, color balls, and various other data as needed.
However, I think the current function is sufficient for printing work that is done in the office.
@vectoradmin
(1.0.042-043)
The line width of PrintMarks>Registration Mark is too thin.
(1.0.042-43) Bad result
Registration Mark is too narrow. The line widths of other marks are OK.
Current Registration Mark:0.011mm (0.03pt)Improvement point:
Improvement point: Use both pt and mm.
Change the line width of the Registration Mark to 0.088mm (0.25pt).
@861475_VctSt For existing documents, it is necessary to reset the printer settings (Print -> Reset button at the bottom), to get the new Registration Mark design.
@vectoradmin
I did a clean install of V with completely removed (cache, settings, etc.).
I also reset the print settings.
The result was the same.
@861475_VctSt I will keep the issue open.
@vectoradmin
@vectoradmin
v1.1.020
Mac OS X10.15.7
macbook air MId2012I cannot output PDFs such as printmarks, bleed, etc.
It also doesn't seem to be functioning properly.
Please check it out.
@861475_VctSt When printing to PDF, select a larger Output size than the printed artboard.
I add this to the backlog, to clarify what is the issue.
@vectoradmin
I guess I set a larger area than ARTWORK.
Oh, that's right.
I get it.thanks
