Rotating using a custom pivot point.
I'm not sure it's a bug. I would like to rotate an item by an exact value but using a custom pivot point. Entering degrees in the Transform panel ignores this red point and uses one of the 9 defined in this panel. Additionally, the point is not fixed to the object, but moves when rotated.
@encart It's not really a bug. Currently, the Transform panel can use only one of those 9 pivot points. I will think of a solution here.
@encart In build 1.0.041 clicking on the selected transform center knob (of the Transform panel) again will deselect (all centers deselected), in which case the custom pivot point is used to transform from the panel also (same for the Object -> Transform commands).
@vectoradmin Tested! Thank you!
