Text "tab" bugs
(Ver.1.0.036 mac intel)
There are some issues with text tab operations. Then, the character string cannot be controlled normally.
The tab ruler and the tab position in the character string do not match.
Tab Try to move the cursor with the right arrow key on the entered character string. When the cursor moves to the front of the tab input, it wraps a few characters in the direction of travel. Even if you advance the right arrow key, the operation of returning a few characters and advancing again is repeated.
The character shape of "-" is displayed at the place where the tab is entered.
@861475_VctSt I added this to the backlog as a bug. Is this in vertical or horiontal text?
@vectoradmin
In both vertical and horizontal , reporting situations occur.
East-Asian Options: The same applies when ON or OFF.
The same applies to 1-byte fonts and 2-byte fonts.
@vectoradmin
I completely removed the updated commercial version from the demo version and installed a new one. I changed the document settings.
Document> General: Ruler
After changing this setting from "mm" to "point", the problem of "1" was solved. "2" and "3" remain defective.Therefore, the issue of "1" is that the above setting occurs when "Millimeter".
@861475_VctSt Looks like (1) is still a bug, as the positions should match regardless of the units.
@vectoradmin
I was working on it now, so I moved it horizontally with the "Character Tool" and took emergency measures.
The Character Tool is convenient because it remains a character string after processing.
May I ask you to fix the bug?
@861475_VctSt Yes of course it will be fixed as soon as possible.
@vectoradmin
(1.0.037 intel mac catalina)
Tab without style seems to be fixed.
But,
When controlled in Paragraph Style, the ruler can only see up to 55 points.
It seems that you can set it by entering a numerical value. Same with Tab Style.
@861475_VctSt Yes, the fixed size modal view is not very good for adjusting tab stops.
But the tab stop styles can be set up and saved from the tab stops panel. And then used to setup paragraph styles.
@vectoradmin
I'm working with the "mm" setting,
The visual of the ruler of ParagraphStyle> Tabs remains the point.
could you fix it?
@861475_VctSt Will be fixed.
@vectoradmin
(ver.1.0.039)
thanks.
I checked it.
It also works in millimeters, and scrolling the ruler is very convenient.
