Using wheel changes the value by a large step. Fields issues
Can you explain to me why the values in the fields, when moving the wheel are so large? How to set the step smaller. Additionally, in the case of text properties, I noticed that after changing the value of horizontal / vertcal scaling with the wheel, it is not possible to revert to the default value.
https://recordit.co/My0ioJpa8T
How to correctly use the function of changing values in fields by dragging up and down. Sometimes it works, sometimes it makes the selection like when editing text. Currently, when using this function, I drag the cursor over the unit name.Sometimes the text size field scrolls even though the entire value and the unit fit inside it
Some fields react for dragging only over/under them, other at full width.
https://recordit.co/Bfu9A8O0IC
@encart It looks like the fields where a scaling value is set are not using the correct wheel scrolling. This will be fixed.
Most fields use vertical up/down dragging, but the mouse must be below or above the editor (inside the left/right margin).
In some fields the dragging is done in horizontal direction (for example the width or X position in the transform panel).
And fields setting the angle value are dragging is done in circle around the field.Should the dragging be only vertical (up/down) for all fields?
CORRECTION: the horizontal dragging works only from the field label (not in the field, where it is used for highlight).
