Cannot select Node handles to adjust
I noticed this issue in the latest beta - When I go to adjust node handles, I can't get the node I'm trying to select to move. I recorded a video of this
It was happening on an older file I re-opened in VS to work on - I quit VS and restarted with a new document and the same issue persisted.
@Boldline Can confirm it happens with old and new documents.
@Boldline In Preferences -> Editing Options disable Select Nodes from All Objects (second column, third from bottom). Looks like a bug, this workaround will help.
@vectoradmin thanks - that worked
