Graphic replacement error
https://youtu.be/RN3rQ2ws1cU?feature=shared
My operations: Group the inner and outer circle graphics on the far left, then duplicate them several times by moving. Enable object snapping. Align the duplicated images to the top-left corner of the larger graphics respectively. Stretch the duplicated images to match the size of the underlying graphics. After completing the operations on several graphics, delete the outer shapes and retain the inner graphics. Then ungroup the graphics on the far left. Extract the inner graphic as the source. When selecting the right-side graphics and using the graphic replacement tool to replace them with the left-side image, errors occurred. Error 1: The graphics to be replaced shifted position. Error 2: The source graphic shifted position, and the action cannot be undone.
0_1744209739620_不可逆.vstylerhttps://youtu.be/YS9nzqmuwRA?feature=shared
0_1744209790504_不可逆-1.vstyler
This is another error effect
