(Windows beta 1.0.021) View > Full Screen (no way back)
Once in full screen view, there doesn't seem to be a way back to the previous view (or at least I can't easily find it).
Quite often when other programs are in full screen mode you still have access to the menu when you move the pointer close to the top of the screen or else you can use a keyboard shortcut, for example Alt+F for File menu etc, then right arrow your way across to the appropriate menu (in this case the 'View' menu).
@Jono Looks like this works only on Mac. I added this issue as a bug to the backlog.
One workaround would be to assign a shortcut to the Full Screen command, or add it to the Context Panel (in customizing toolboxes).
@Jono The menu is kept on now in full screen mode, in the new build (1.0.022).
