Magnetic close of a path seems to not work now - unless I missed a new setting
Loving the new update! I was trying to close a path using the magnetic grab that worked well in version 208. It doesn't seem to work now, unless there's a new toggle I am missing. I saw something in the release notes for 209 about the ability to interact with an existing stroke...
Here's a video of me trying it as I remembered it from 208. I did it twice and then zoomed in to show the line was close but not dead on and it did not close the path and end the live pen as a result
@Boldline Magnetic close works here, it does not depend on any option. I will test more to try to replicate it.
On changing existing nodes: there is a new option in the context panel "Adjustments". If disabled, then the pen tool will not react when hovering over existing nodes or curves and will not be able to change those. But the magnetic close should still work.
@vectoradmin this worked again when I made a new document
