    Interweave two texts
    17 Posts 5 Posters 82 Views 5 Watching
      Subpath @marce
      @marce
      As @li-xiao wrote, you need to close the orange shape first
        marce @Subpath
        @Subpath hi Subpath. Why there are lines when you interwine the object?
        Memory 48gb ddr4
        NVMe CT100p 1TB
          VectorStyler @marce
          @marce said in Interweave two texts:
          If you refer to those thin lines at overlapping parts, those are rendering (clipping) artifacts and are caused by the antialiasing in the CPU based rendering engine.
          You can use the GPU based rendering engine (View -> View using GPU) and then it should not be visible.
          M S 2 Replies Last reply Reply Quote 0
            marce @VectorStyler
            @VectorStyler mmm... this what i get when using such option:
            Memory 48gb ddr4
            NVMe CT100p 1TB
            VectorStylerV M 2 Replies Last reply Reply Quote 1
              VectorStyler @marce
              @marce It seems that the GPU preview is not working there.
              On some Windows machines it still has issues
                Subpath @marce
                @marce
                As @vectorstyler already wrote is Antialiasing related
                  Subpath @VectorStyler
                  @VectorStyler said in Interweave two texts:
                  Have no such Menu Point in the View Menu.
                  (i use the latest Version)
                  • L Online
                    Li Xiao @Subpath
                    @Subpath You have to change the Compute Engine in Settings first for it to display
                      Subpath @Li Xiao
                      @Li-Xiao
                      Thank you
                      I already had suspicions along those lines.
                        marce @marce
                        Is there something i can do to solve this issue?
                        Memory 48gb ddr4
                        NVMe CT100p 1TB
                          VectorStyler @marce
                          The intertwine or the GPU preview issue?
                          The GPU preview problem os most likely caused by some incompatibility with the CUDA driver.
                          What is the NVidia CUDA version you have?
