    Interweave two texts
    18 Posts 5 Posters 108 Views 5 Watching
      Subpath @marce
      @marce
      This little tutorial of mine may be helpful
      https://www.vectorstyler.com/forum/topic/5572/intertwine-feature-and-a-way-to-fake-gaps
      • L Offline
        Li Xiao @marce
        @marce said in Interweave two texts:
        Then? I click, but nothing happens.interwine.vstyler
        This is because the orange shape is an open path (non-closed shape)
          Subpath @marce
          @marce
          As @li-xiao wrote, you need to close the orange shape first
            marce @Subpath
            @Subpath hi Subpath. Why there are lines when you interwine the object?
            Memory 48gb ddr4
            NVMe CT100p 1TB
              VectorStyler @marce
              If you refer to those thin lines at overlapping parts, those are rendering (clipping) artifacts and are caused by the antialiasing in the CPU based rendering engine.
              You can use the GPU based rendering engine (View -> View using GPU) and then it should not be visible.
              M S 2 Replies Last reply Reply Quote 0
                marce @VectorStyler
                @VectorStyler mmm... this what i get when using such option:
                Memory 48gb ddr4
                NVMe CT100p 1TB
                VectorStylerV M 2 Replies Last reply Reply Quote 1
                  VectorStyler @marce
                  @marce It seems that the GPU preview is not working there.
                  On some Windows machines it still has issues
                    Subpath @marce
                    @marce
                    As @vectorstyler already wrote is Antialiasing related
                      Subpath @VectorStyler
                      @VectorStyler said in Interweave two texts:
                      Have no such Menu Point in the View Menu.
                      (i use the latest Version)
                      • L Offline
                        Li Xiao @Subpath
                        @Subpath You have to change the Compute Engine in Settings first for it to display
                          Subpath @Li Xiao
                          @Li-Xiao
                          Thank you
                          I already had suspicions along those lines.
                            marce @marce
                            Is there something i can do to solve this issue?
                            Memory 48gb ddr4
                            NVMe CT100p 1TB
                              VectorStyler @marce
                              The intertwine or the GPU preview issue?
                              The GPU preview problem os most likely caused by some incompatibility with the CUDA driver.
                              What is the NVidia CUDA version you have?
                                marce @VectorStyler
                                @VectorStyler Hi VS, the reported version is "13.0.98"
                                e36509e1-8892-4fe3-860b-c73c24ab2b44-image.png !
                                Memory 48gb ddr4
                                NVMe CT100p 1TB
