    Just a Pattern
    43 Posts 7 Posters 60.9k Views 7 Watching
      Not a tutorial, just for inspiration
      I like to experiment to create patterns
      In one of my experiments in VectorStyler
      I found this result.
      I don't remember the steps how I did it
      but I like it and maybe someone here likes it too πŸ™‚
      L 1 Reply Last reply Reply Quote 8
      • L Online
        Li Xiao @Subpath
        @Subpath
        Great pattern!
        The production method is apparent at first glance.
        I can try to replicate it approximately
        but achieving an exact match will require some additional time and effort.
        0_1718204098829_Pattern.vstyler
        S 1 Reply Last reply Reply Quote 7
          Subpath @Li Xiao
          @Li-Xiao
          Great, well done! πŸ‘
          Yes, it's not really complicated to do and
          I think it mainly lives from the added gradient
          • H Offline
            Harry @Subpath
            @Subpath @Li-Xiao Great pattern! Some tweaks and here we go:
            S 1 Reply Last reply Reply Quote 4
              Subpath @Harry
              @Harry
              nice,
              seems that pattern sparkle some inspiration πŸ™‚
              Btw everybody is pretty welcome with their own variation
                I fed Nodebox with the pattern.
                Here a post of mine about Nodebox
                https://www.vectorstyler.com/forum/topic/4119/a-kind-of-patternnodes-for-windows-free-win-mac
                A while ago I created a Nodebox node tree, with which I can
                replace one object from an SVG file with another. I use this
                to replaced the rectangles from the original pattern with a star.
                Although i think something like this is definitely possible with
                the Repeater. Since it uses symbols.
                  Another pattern created with Nodebox and then edited in
                  VectorStyler. These two are pretty good companions.
                  The Colors where made with VectorStyler's "Colorize" Feature.
                  Menu > Effects > Replace Colors > Colorize. I love it πŸ™‚
                  Btw. did you know that you can create a Action with it!
                  Here is a video that shows the steps creating the first one.
                  Here is my first version
                  And here the whole thing modified with an
                  Offset Shape Effect and the Corner Tool.
                    Repeater Pattern
                    Just a Quader, set Repeater to Concentric
                    and size to Random
                    for Random Coloring
                    Fill your Pattern with a color
                    select it
                    go to Menu > Effects > Replace Colors
                    choose > Colorize
                    use the randomize Feature until you have some
                    coloring you like
                    ( if you found a nice one, "save it as a preset!" )
                    Selecting Tiles of a Pattern/Mosaic is possible this way
                    choose a shape
                    put it over your Pattern
                    select it
                    then select:
                    Menu > Select > Select Others
                    then choose
                    • Select Inside Shapes
                      or
                    • Select Intersecting Shape
                      (thanks to @Li-Xiao for this, did not know this before
                      he mentioned it in a post)
                    I applied a Gaussian blur to the shape and placed it
                    under the pattern selection
                      This pattern is made entirely in VS.
                      The steps are as follows:
                      I made an object with a dashed line
                      and duplicate/transform it.
                      Convert the dashed outline into Paths.
                      Replace the Paths with a Star Shape
                      via Find/Replace in VS.
                      Select Parts of the Pattern with Select inside
                      and recolor it
                      you could also take a look in this thread here:
                      https://www.vectorstyler.com/forum/topic/4565/best-way-to-achieve-this-effect/4
                        Another nice find, made entirely in Vectorstyler
                        with a little help from corner tool and the
                        colorize feature πŸ™‚
                          While i was I looking at this pattern, I had the idea that
                          it might look like a peacock's tail, so I create this one.
                            well, I think you can also see it as a kind of pattern
                            saw this interesting design made with CorelDraw
                            and i recreated it in VectorStyler
                            (Shapebuilder was involved)
                              made a variation, also all in VectorStyler
                                some further variations of this design
                                seems that i am not short on Ideas πŸ™‚
                                will do a tutorial which tricks VectorStyler offers
                                to get such results
                                the first tutorial is online, you found it here:
                                https://www.vectorstyler.com/forum/topic/4624/using-the-extend-path-tool-to-adjust-a-blend
                                this second tutorial shows how to replace dashes of a stroke with another shape
                                https://www.vectorstyler.com/forum/topic/4625/replace-dashed-line-strokes-with-another-shape
                                  Another pattern, created in Vectorstyler
                                  is an overlay of different patterns and
                                  experiments with combined stroke stripes
                                  IngolfI 1 Reply Last reply Reply Quote 6
                                    I'm still experimenting with the possibilities Stroke Stripe offers
                                    for creating patterns.
                                    It started with that simple pattern below, I added an offset shape effect
                                    and used Stroke Stripe with Boolean Combine on it.
                                    The Colors were made with Colorize.
                                    To get such patterns from Stroke Stripe it should be closed shapes
                                    and then do a Boolean Combine with it.
                                      Found some new ways for creating Pattern in VS.
                                      You could also take look at this link
                                      https://www.vectorstyler.com/forum/topic/4843/inverted-wave-zig-zag-with-the-outline-zigzag-shape-effect
                                      Here just one Result, but many many Variations
                                      are possible this way
                                        created a, color-wise, somewhat structured version.
                                          A fairly simple pattern, what made it special was
                                          the use of β€œcolorize” with my own palette.
                                          Menu > Effects > Replace colors > Colorize...
                                            another one of my pattern experiments
                                            also colored via colorize like the one above
