Tracking Keyboard Shortcuts issue
Correct me if I'm wrong, but I thought the default keyboard shortcuts for tracking was option-right arrow and option-right left arrow? I know we discussed this a month back or so...
Each time I upgrade to the newest build, it seems to reset the keyboard shortcuts for tracking to what is in the screenshot attached below.
Yes, you're right. In my case nothing has changed.
Have you checked if you have assigned the correct combination to another function?
@encart That's interesting. Maybe it's a bug in the Mac version that reverts it to another shortcut? @vectoradmin - are you seeing this occur on the mac side or might this be an issue with my older OS?
Also interesting that your shortcut is called "Option-Left" and on Mac, the equivalent is "Option-Numeric-Left". Maybe that is a PC/Mac nuance
@vectoradmin could we expand the Application Shortcuts panel to allow for full view of the keyboard shortcuts? (marked "A")Several get cut off. Either expanding the panel on the left side (marked "B") or allow for it to be pulled to be wider on the right side (marked "C")?
@encart said in Tracking Keyboard Shortcuts issue:
Good question - I have not knowingly done that but I will take a closer look
@Boldline
You can resize the columns
https://recordit.co/n3cHSR40Is
@encart Thanks! This is true and that works, but you're still encroaching on the other column doing that. It's not a deal-breaker, but a little more room to work with would help in my opinion
@Boldline In some cases when updating, or when reseting, it may revert to the default.
Would Option+Control+Left/Right be a better default?
@vectoradmin Was this not already the default? We had discussed this a few weeks back
@Boldline It is the default when not in text editing mode. But it seems that when the text is edited, the Option+Control+Comma is still assigned.
