Control-V to paste image copied from web into document
  • I can't remember if this was available in previous versions of VS, but when I copy an image from the web (control-c), I can't paste it directly into VS. I have to save the image first and then import it. (This is fine for images already downloaded) Am I missing something to allow me to directly paste a copied image into VS?
  • @Boldline Yes, pasting copied images from the browser directly would be nice. 👍
    Not sure how much it helps, but if you run Safari you can however drag the image from Safari over VectorStyler's icon in the dock, and the app will create a new document with that image. Unfortunately this doesn't work with other browsers (I guess it's a sandboxing limitation?).
  • @b77 I hope this is a fix @vectoradmin could do at some point - I didn't realize how many times I go and grab something off the internet to use in a design
