Could Stroke panel and Stroke Width Panel be combined?
Was just curious if the Stroke panel and the stroke width panel could/should be combined into one panel?
@vectoradmin , you probably have a good reason for it being two panels, but I figured it was worth bringing up to see
@Boldline I'm not sure about this one. The Stroke panel is large as it is. The Stroke Width panel contains options used only when editing the width profiles.
But these can be docked into one column.
