Really compatible with 10.11?
  • Well, I am using an iMac Core 2 Duo (2007) with Mac OS X 10.11 and all the versions of VectorStyler that I have tried close when I try to run them, with a crash message.
    Process: VectorStyler [2012]
    Path: /Applications/VectorStyler.app/Contents/MacOS/VectorStyler
    Identifier: com.vectorstyler
    Version: 1.0.039 (1.0.039)
    Code Type: X86-64 (Native)
    Parent Process: ??? [1]
    Responsible: VectorStyler [2012]
    User ID: 501
    Date/Time: 2021-07-01 11:40:10.878 +0200
    OS Version: Mac OS X 10.11.6 (15G22010)
    Report Version: 11
    Anonymous UUID: 2142836B-6D14-BA73-D9A5-FA56ACDEA4F4
    Time Awake Since Boot: 5700 seconds
    System Integrity Protection: enabled
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
    Exception Codes: 0x0000000000000001, 0x0000000000000000
    Exception Note: EXC_CORPSE_NOTIFY
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0 imgpack.dylib 0x00000001231abcf3 img_ztkInitBaseImageScheme + 86
    1 imgpack.dylib 0x00000001231abe51 img_ztkAddAutoImgScheme + 216
    2 imgpack.dylib 0x00000001231acacf img_ztkInitImageGlobals + 187
    3 ztkcore.dylib 0x0000000120de40b8 plg_ztkLoadPlugin + 235
    4 images.dylib 0x0000000123115376 ModuleInit + 138
    5 ztkcore.dylib 0x0000000120de27e2 plg_ztkLoadPlgModule + 330
    6 ztkcore.dylib 0x0000000120de2b22 plg_ztkGetPlgModulePackage + 26
    7 ztkcore.dylib 0x0000000120de3ef1 plg_ztkLoadPluginPackage + 120
    8 ztkcore.dylib 0x0000000120de4087 plg_ztkLoadPlugin + 186
    9 ztkcore.dylib 0x0000000120de4972 plg_ztkLoadResidentPlugins + 67
    10 ztkcore.dylib 0x0000000120de5b43 plg_ztkSearchForPlugins + 225
    11 ztkcore.dylib 0x0000000120da70fa ztkInitMainLibrary + 154
    12 zcfcore.dylib 0x00000001194aee4d LoadZTKLibrary + 330
    13 zcfcore.dylib 0x00000001190f31b2 ZCoreLib::ZCoreLib(char const*, bool) + 120
    14 zcfui.dylib 0x0000000117a99970 zcfMain + 48
    15 com.vectorstyler 0x000000010c75dcaa 0x10c75c000 + 7338
    16 libdyld.dylib 0x00000001133c15ad start + 1
    Is it really 10.11 compliant? Is the problem my old mac? Don't they say in requirements that it can work on old macs? What then are your actual requirements?
    I'd really like to give it a try and maybe purchase it as another option in addition to the ones I already use. But for me it is important that my system be supported. I can understand that they are not, but I like it when they do. Now, I understand very badly that it is said that support exists, and in the end it is not so. That is even more annoying.
    Regards
    MacTerrassa
    P.S. Message translated mechanically as I do not speak English, I apologize if I have not expressed myself correctly.
    @MacTerrassa said in Really compatible with 10.11?:
       EXC_BAD_INSTRUCTION
    Per the crash log, it looks like the Intel CPU is not supported. It is compatible with 10.11 but the Mac might be a problem.
  • @vectoradmin Is a iMac (20", 2007) 2,4 GHz Intel Core 2 Duo with 6 GB RAM, ATI Radeon HD 2600 PRo 256 and a SSD Samsung 850 EVO 500GB (updated)
    Intel Core 2 Duo
    The Intel Core 2 Duo is not supported. VectorStyler uses SSE4.2 instructions, that are not available on those.
  • @vectoradmin Thanks for answering. Although I regret they do not support 😞
    Perhaps they could better explain in the help what hardware is supported or not. I have rechecked it, and I do not see more that it has been tested on 2010 macs and that it can work "older" but it does not say what or what requirements you really need.
    From what I understand, the note about the use of Metal is not mandatory either. I have already come across other programs that the problem is out there, still indicating 10.11 as a minimum.
    When the requirements require a specific hardware in addition to a system version, for those of us who are not experts it is better to indicate the hardware based on the supported Apple models so that we can better understand if it works or not.
    Regards
    MacTerrassa
