    No pressure, no realtime preview
    16 Posts 4 Posters 53 Views 3 Watching
    • K Offline
      Kurvaistenitmar
      Hi,
      I just grabbed my old wacom graphire which works with literally all app and even on Android well and tried with this app.
      Problem 1: pressure is not recognized (I chose pressure from dropdown).
      Problem 2: I was not able to see the brush in real time, just the hairline turned to thickness after releasing the stroke. It worked 20 years ago in all apps I used.
      I checked the preview in settings, no fun.
      Any ideas? Thanks
      VectorStylerV M 2 Replies Last reply Reply Quote 1
        VectorStyler @Kurvaistenitmar
        @Kurvaistenitmar Are you on Windows or Mac?
        On Windows:
        In VectorStyler there is a Use Tablet Driver option in the Settings -> Application section.
        Try that, and also try different modes of the Windows Ink option in the Wacom settings.
        K 1 Reply Last reply Reply Quote 0
        • K Offline
          Kurvaistenitmar @VectorStyler
          @VectorStyler Hello, Win11.
          I tried 'use tablet driver', it put cursor 5cm away from the pen tip visual representation and drew a zigzag instead of line. Without tablet driver it draws where it has to, but no pressure.
          It is a pretty old wacom and pretty old driver, no windows ink option in it. But it works with Concept, DrawPlus (my all time favorite vector suite) and Affinity.
          I have a newer one somewhere (a big one), I will try it, that has more modern driver.
          But: what is about the real time line thickness? That is a key to me.
          Thanks.
            @Kurvaistenitmar I will try to replicate this tablet issues.
            For previewing: in Settings -> Direct Preview enable the "Brush Tool" and "Pencil Tool" option
            • K Offline
              @VectorStyler Thanks, brush enabling worked. Pressure still does not work on old Graphire tablet.
              How could I switch off constant recalculation of the stroke? It is pretty disturbing to see everything 'wobbles' on the screen. I could optimize a stroke later if needed (at least I hope, but that is used to be a standard). I already switched off smootings, etc. to 'none'. Thanks.
              K VectorStylerV 2 Replies Last reply Reply Quote 1
              • K Offline
                Kurvaistenitmar @Kurvaistenitmar
                I aslo found a bug: after moving the VectorStyler to the secindary monutor display (or back) the white page disappears completely (drawing area).
                  @Kurvaistenitmar said in No pressure, no realtime preview:
                  Reduce the Smoothness on the context panel.
                  • K Offline
                    @VectorStyler It is 0,1.
                    • K Offline
                      It does it with mouse, too. I try to draw a huge rectangle on the canvas and the first corner blinks while I am on finishing it. Very interesting.
                        @Kurvaistenitmar Not clear what could cause this. Can you send me a recording of this?
                        • K Offline
                          @VectorStyler How can I send you a video (screen recording)? MP4 is not supported.
                            Boldline @Kurvaistenitmar
                            @Kurvaistenitmar you can upload a video to a 3rd party transfer site and send the link code on here or to the developer's email.
                            • K Offline
                              Kurvaistenitmar @Boldline
                              @Boldline Thanks. Where is the developers email?
                                @Kurvaistenitmar
                                csraba at vectorstyler.com
                                • K Offline
                                  @VectorStyler Sent
                                  • M Offline
                                    marce @Kurvaistenitmar
                                    Hi,
                                    Any ideas? Thanks
                                    Hi. I uploaded a video. In my case, the Wacom is working ok, pressure is recognized, BUT no realtime preview even i choose the recommended settings and restarted VS.
                                    https://icedrive.net/s/NazYzNuRD6kR43BCtf6wZYSztfD7
                                    Memory 48gb ddr4
                                    NVMe CT100p 1TB
