Bitmap and layout apps?
@Petar_MK Yes, the panel Kyriakos mentioned is in VectorStyler's Panels menu > Effects > Image Effects.
There are so many features, I don't know where to start.
Maybe (some) photo editing features in near future?
@Petar_MK Which photo editing features you would like to see?
Well, all under "Image" menu from Photoshop, raw editing, all filters and layer effects from Affinity Photo (live), all adjustment layers (live, too) from PhotoLine (https://www.pl32.com/).
Yes, I know this is an enormous job, but one at a time. No hurry.
@Petar_MK Couple of observations:
- in VS all image filters (visible in the Effects menu and in the Image Effects panel) can be used as adjustment layers and adjustment filters on object background.
- raw editing probably not going to make it into a vector app.
- most of the blur, distort., noise and colour effects of Affinity are available in VS, as live effects, and also usable as adjustment effects
- most of the VS blur effects have some interesting parameters.
- there is a plan for the future to add more image effects, that are suitable for a vector app.
A quick adjustment effect guide:
- you can add adjustment effects to layers in the Layers panel.
- you can turn any object (or group) into an adjustment layer, localized by the object shape or group content as a mask. Use the Object Options -> Adjustment Layer checkbox.
- you can add adjustment styles in the Appearance panel that are local for object styling.
Maybe there is some missunderstanding between us. I suppose all these features to be applied on bitmaps, not on vectors (only).
@Petar_MK I suppose you mean being able to open and edit a photo in a bitmap, fixed-resolution document format and canvas?
@Kyriakos said in Bitmap and layout apps?:
Yes, just like in Photoshop.
@Petar_MK @Kyriakos Doesn't VS already have some bitmap halftone kind of function built in already?
I agree with @vectoradmin that it's probably important to not stray too far from keeping the application a vector-based focus. That said, the ability to do a few things in raster is helpful - I need to play with it more, but the halftone bitmap abilities already inside VS are awesome
