update 1.2.083
VectorStyler 1.2.083 release notes
- Fixed a regression in mesh warp node insertion
- Use picked color in path brush as a default color
- Improved color mode handling when opening Illustrator files
- Improved selection of objects with offset stroke
- Fixed a bug in exported EPS files
- Fixed a bug in the "Select Inside" double click mode
- Fixed a bug in popup slider positioning with multiple screens
- Restored corner mode for Option key in Pen tool
- Paste into view center by default
- Do not show selected object highlight while in the gradient editor tool
- Fixed a bug with the color palette panel
- Improved tablet support in painting tools
@VectorStyler Thanks for the fast updates!
P.S. Help / About VectorStyler shows version 1.3.000. Is it a 1.3 or a typo?
@Harry That is a typo, I will have to fix it now.
@VectorStyler said in update 1.2.083:
could Shift-Command-V and Shift-Command-B be set up to do the opposite of what the "paste keeps position" is checked for? So the default for VS is currently paste in center view and Shift-Command-V and Shift-Command-B paste in place respectively. I'd more in a situation where I would usually want the "paste keeps position" active and occasionally paste in center. For those rate times, I would like to use the keyboard shortcut so I don't have to go change it in settings each time.
@Boldline said in update 1.2.083:
I will try to add this.
Thank you for this!
As of the 1.2.083 version, I can feel significant improvement in drawing by stylus. I have the best results with Windows Ink enabled and "Use Tablet Driver" in VS disabled.Tooltips are still missing when you hover over the icons with the stylus, though.
@Harry said in update 1.2.083:
I will try to fix this
I tried to replicate this. Both with "Use Tablet Driver" and without.
The tooltips are working, but are sensitive to the stylus movement and if moved they will not show.
One solution is to reduce the tooltip delay in Settings -> User Interface to 0.1 secs
