update 1.2.077
    VectorStyler 1.2.077 release notes
    • Fixed a PDF importing bug with rotated text
    • Improved pattern brush handling
    • Fixed a bug in importing pattern brushes from AI files
    • Fixed a selection bug in the path brush tool
    • Entering outline mode should not cancel duplication transform
    • Contour panel should create new contours with the current options
    • Typing text with paragraphs selected with triple click should replace the paragraphs
    • Ungrouping transformed text frames should keep the correct transformations
    • Show current width in stroke width panel when selecting with the stroke width tool
    • Selecting shape from the menu should keep the object position
    • Improved path combination options and speedup of certain path operations
    • Convert to curves should work also when the offset tool is active
    • Use the current transform each mode when flipping objects
    • Fixed a bug in the path eraser tool
    • Improved AI file importing with older AI formats
    • Selecting with the node tool in composited groups should not select the other objects of the group
    • Fixed an SVG exporting bug when exporting the whole canvas
    • Fixed an object duplication issue with moved parent layers
  • @VectorStyler Thank you! These are great fixes and improvements. Makes using VS a lot easier. I greatly appreciate the regular updates to VS!
  • Releases Page - Links Broken
    MacOS - Ventura 13.7.7
    Safari - 18.6 (18621.3.11.19.1, 18621)
    Hi:
    For me all the download links for the 1.2.077 update on the releases page are broken. Tried all of them as a test.
    Regards,
    MWK
