update 1.2.054
    VectorStyler 1.2.054 release notes
    • Option to allow using (linked) object styles as default drawing styles.
    • Improved alignment of number sliders.
    • Converting a single glyph to curves should result in a single object, not a group.
    • Fixed a refresh bug when changing styles inside transformed groups.
    • Allow click selection of parametric shapes in the node editor.
    • Convert to curve should be disabled if no conversion is possible.
    • Show color palette margins inside popover views also.
    • Changed the popover window style.
    • Creating number variables should check for name overwrite.
    • Do not paste text into a shape text as a frame.
    • Improved exporting blend modes to SVG and PDF.
    • Fixed a bug in breaking apart cloned objects.
  • @VectorStyler said in update 1.2.054:
    Yeah, I suppose this is what made Verctorstyler beautiful again? 🙂
    @Ingolf THis change was about the removal of the pointing bubble frame around view opened from buttons
