Unusual use of ShapeBuilder for colorizing in VS
  • Unusual use of ShapeBuilder for colorizing in VS
    Regulary one would use the ShapeBuilder to build a
    Shape from a bunch of shapes.
    But the Shapebuilder is also surprisingly helpful in creating
    a selection order of shapes, which is useful for the
    Colorize function in VS.
    The Colorize function in VS has a nice feature: it places
    the colors of a palette on objects in the order in which
    the objects were selected.
    This can be used to define in which order a gradient or any color
    palette should follow a number of object shapes. The problem is
    how to get such a defined order of selected objects? Normally you
    have to laboriously select them one by one in VS. None of the
    selection frames work for this.
    So I thought about this problem for a while and then came up with
    the solution of using the ShapeBuilder for it.
    Because if you select objects with the ShapeBuilder, VS registers
    the order in which you select them, and this way the Colorize function
    gets the needed object order in which it will place the colors of
    a palette on the objects.
    Using the Shapebuilder for this also enable to draw over shapes to
    select/collect them instead of having to click on them one by one.
    Here are the required steps to colorize a bunch of objects
    this way:
    Select the ShapeBuilder and choose a color which is "NOT" in
    your design. Then draw over or pick your Objects with the
    ShapeBuilder in the order/direction that your color palette
    should follow.
    Switch to Transform Tool to deselect the ShapeBuilder
    Select the Magicwand, and select the colored objects.
    Call the Colorize Function with a Palette of your choice.
    (Menu > Effects > Replace Colors > Colorize)
    thats all
    Addional Note:
    I used a palette with 10 colors and selected 10 objects
    Here a Video how to do it
