    Resetting the Rotation and Skew commands
    5 Posts 2 Posters 6.6k Views 2 Watching
    • H Offline
      hbalcic
      We can't calculate how many degrees we rotated the lines. Can we add Alt + Click or another shortcut command to the Rotate and Skew toolbars to fix horizontally rotated lines? Same goes for Skew.
      0_1732534924466_Reset Rotate&Skew.vstyler
      • H Offline
        hbalcic
        This is how the AI ​​Rotate reset works.
        0_1732536590535_Rotate_AI.mp4.zip
          VectorStyler @hbalcic
          @hbalcic said in Resetting the Rotation and Skew commands:
          Was the line rotated or was edited and a node moved with the node tool?
          For rotations and skewing the Effects -> Remove All Shape Effects will remove the transforms.
          • H Offline
            hbalcic
            The line was drawn with the "Pen Tool". I added the document to the first message. Angle: 0° is visible.
              @hbalcic I will try to find a solution for this. Meanwhile, use the Angle value in the Transform panel.
