update 1.2.046
VectorStyler 1.2.046 release notes
- Export transparent mesh gradients to PDF as images.
- Fixed a Separate Path bug on composite shapes.
- Fixed selecting multiple canvases in the Canvas panel.
- Duplicated repeater objects to correctly detach on changes.
- Allow selecting number variables from the Context panel (example: stroke width).
- Repeating the Scale operation should use the correct center.
- Do not show duplicate shape properties in the context panel.
- Holding shift while duplicating should keep snapping on.
- Do not snap to shape angles when point snapping is enabled.
- Separating dashed strokes with profiles should split the profile correctly.
- Show scaled font sizes in the panels.
- Selecting spot colors should change the color only, not the tint.
- Changing tint of spot colors should not change change the color.
- Keep options for the Color Variations panel after a restart.
- Add gradient flip button to various color and image effects using the gradient selector.
- Disable image trace button if both storke and fill tracing is unchecked.
- Undoing canvas data source selection should update the canvas.
- Added automatic artboard count for canvas data sources.
- Better cursor direction handling with text selection.
- Do not show decimals in color palette list.
- Do not add paragrapjh space before at the start of a frame.
- Fixed a text wrap bug.
- Fixed a regression in selecting Drop Capital and paragraph numbering options.
- Fixed a bug in paragraph stretch options editing.
- Fixed several tab stops related bugs.
- Improved update of color panel with text fill or stroke info.
- Detaching from iconified panel groups to remove section correctly.
- Better default stretching options for justified text.
- Allow slice renaming with mouse click in Slices panel.
- Added option to select another node after deleting a node in the path editor.
- Break apart the path when removing nodes with disconnect.
- Set correct position of objects after releasing a repeater.
impressive list, as always
@VectorStyler Impressive work! We appreciate your hard work and passion for the VS project
