Text Wrap
Hi,
I'm not quite sure how Text Wrapping works. In my mind, and looking at other apps, you assign the Text Wrap to the shape you want the text wrapped around. This is also explained in the documentation.
However, I can't get it to work (maybe it isn't entirely implemented yet?). If I have a shape, and go to Text-->Text Wrap options, I can set the various options, but nothing happens, and there's no indication I even have set it to wrap text. Sometimes I type in a value, but it resets to zero everytime.
Also, when I select the text and the shape, and then choose Text--> text Wrap Options and change a value, the app crashes.
@Gremriel It should be working: https://recordit.co/LOzi0pdLcS
Maybe there is some specific settings or something with the shape. If there is an example that is broken, please send it to me by email.
It's working for me as well, i need to keep toggling "Preview" to see a live preview but other than that it works.
You are using a Text Frame and not a Text Shape right?
Hi,
I do the same steps as in the recording, but as soon as I choose a mode, the app crashes (it locks up, to be more precise). The text is just regular Times New Roman, the shape is a rectangle.
@Kyriakos yes, I use the text tool and drag a frame.
@Gremriel Some of us use the app on a Mac, some on Windows. You can specify that in your signature — see 'Edit Profile' under your account.
@b77 Yes, I should have mentioned I'm on Windows. I changed my signature
@Gremriel I just checked this on Windows, and it looks like there is a bug. It can be replicated easily. Will try to have a fix in the next build.
