update 1.2.038
VectorStyler 1.2.038 release notes
- Improved tablet pen support.
- Fixed a UI refresh issues when restoring window from minimized state.
- Snap to existing panel sizes when resizing a panel.
- Fixed a bug in the style picker tool.
- Fixed a bug with the Erase blend mode when using with image effects.
- Added an option to render vector brushes as images.
- Allow Control modifier in number editor fields (Windows).
- Menu focus should follow cursor for disabled case also (Windows).
@VectorStyler Excellent! Will check it out when I have a chance to update
@VectorStyler said in update 1.2.038:
Would you be able to elaborate on this update feature?
Thank you for the update and the fixes! Your hard work is always appreciated and Vs becomes a more efficient and polished product all the time.
@Boldline said in update 1.2.038:
The vector brushes use the bend shape distortion to stretch vectors along a shape. This also works for images when the Distort Images is enabled.
But, in some cases when the whole brush is an image (as in Affinity), it can be better to use the image distortion (instead of shape) effect for this.
This will also distort gradients as an image.
