Regarding Guidelines
Hi,
When I drag a guide onto the canvas, it is not smooth. The guide jumps to the cursor position, which makes it difficult to position it. I know I can adjust the position with precision in the Guidelines panel, but I would like to quickly set up the guides and then finetune it.
@Gremriel This is not cleat, a quick video might help (using recordit). What are the snapping options enabled in View -> Guides menu?
The new guideline (dragged from the ruler) should follow the cursor position.
Hi,
I noticed that when I first open the app, and create a new document, dragging a guideline from the ruler is smooth and works as intended. When I create a new document, and drag a guideline is also smooth. However, when I go back to the first document, dragging new guideline starts to "stutter"
@Gremriel Is this on Mac or Windows? Looks like some sort of refresh issue.
If the first document is still available as a file, could you send it by email to me. Thanks!
Hi,
I'm on Windows 10. I have no file; it happens on a blank document as soon as I open a second document.
@Gremriel Yep, got it replicated. Problem occurs after multiple documents are opened, and switched between.
