Display text size in points
  • My basic units are set to inches. Given that, when setting text, the properties shown for text height are also labeled in inches, rather than points. But the drop-down shows points. And the size shown in inches is not correct, either: for 24 pt text, the size shows as 33 inches.
    Can this be controlled somewhere? For most letter-sized projects, I'd prefer text size in points, although I can think of use cases where I would want size in inches - sign-making, for example. (And pixels, for UI design.)
    The 24 pt size should show as 0.33 inch (maybe the field is small and the 0. is not visible).
    Will add a separate unit option for font sizes as this is a problem.
