update 1.2.032
    VectorStyler 1.2.032 release notes
    • Fixed a crash with blending text shapes.
    • Improved large image support.
    • Allow exporting with very large image sizes.
    • Fixed a regression with click+drag selection for the node tool.
    • Renamed the "Common Snapping Options" to "Global Snapping Options".
    • Fixed the HSL color mode slider sequence.
    • Color variations should display original color only at the center.
    • Highlight selected starting node correctly.
    • Changed the Transform panel layout.
    • Display current preset name in Snapping Options panel.
    • Fixed a UI refresh bug.
  • @VectorStyler Thank you for getting these updates out so quickly. No doubt you were probably ready for a short reprieve from eliminating bugs after uploading the recent build, but you got right on the vital fix that affects daily use and then even addressed a number of other bug fixes as well.
