update 1.2.029
    VectorStyler 1.2.029 release notes
    • Improved color font text expansion with ligatures.
    • Fixed expanding SVG color font text with current color.
    • Data source CSV file reading with Unicode characters.
    • Improved moving text on path inside a complex design.
    • Fixed a magic wand regression.
    • Fixed a memory leak issue.
    • Deleting from Layers panel should delete the whole object in text editing mode.
    • Preview size when dragging objects in the Layers panel.
    • Fixed a crash caused by deleting cloned objects.
    • Assigning color to compound paths when one path is a text shape.
    • Previewing and applying intensity oiptions in random repeater geometry.
    • Remove member objects from selection when transforming.
    • Changed the height of the font previews in the font list.
    • Improved compound shape from cloned objects.
    • Allow drag and drop between layer panels of different canvases.
    • Canvas panel drag and drop improvements.
    • Importing SVG with box placement should position it correctly.
    • Fixed a crash caused by deleting guidelines.
  • @VectorStyler ☺ Thanks ☺
  • @VectorStyler I updated but since then VS always opens with the crash window. Should I uninstall and reinstall VS?
  • @Pat You can manually delete the crash files in x:\ProgramData\NumericPath\Crash Logs\
  • @Li-Xiao Indeed, thanks ☺
  • Fantastic!
    There can be still issues with the MSI updater. The current one should not create a new program in the settings, but it seems that in some cases it does not replace the whole VectorStyler.
    If there are issues like wrong text in the UI (menu names, etc) then remove all existing VectorStyler installs and reinstall it.
  • @VectorStyler As an added bonus, my taskbar pin survived the upgrade. It's still orange, but it didn't create duplicate entries in Programs and Features this time.
