update 1.2.025
    VectorStyler 1.2.025 release notes
    • Pick colors in the bucket fill tool by holding Shift
    • Added an export option to set artboard exporting order for PDF and Postscript.
    • Added option to not clip artboard when exporting to PDF or SVG formats.
    • Fixed a problem with spot color output to PDFs.
    • Fixed an EPS file importing issue.
    • Path eraser tool to select all changed shapes.
    • Image place tool (importing) should position the image according to the dragged box.
    • Fixed a crash when copying grouped text frames.
    • Do not allow dragging of disabled number fields.
    • Update export size when resolution changes.
    • Export defaults to resolution set in document setup.
    • Allow saving path node selections in the Selection panel.
    • Select with multiple selection presets.
    • Added a Convert Colors option to printing.
    • Improved the hex input in the Color panel.
    • New action to paste text without formatting.
    • Improved image info layout in the Links panel.
    • Change units in number fields by typing the unit symbol only.
    • Save a default fill style when creating character styles.
    • Save character style info with paragraph styles.
    • Fixed a shape paint object updating issue
    • Allow style picking from locked objects also.
    • Fixed a workspace creation and loading issue.
    • Images dragged from the Links panel should be added at the correct resolution.
    • Allow text deletion with Shift + Backspace on Windows.
    • Fixed a grid refresh issue on Windows.
