update 1.2.022
VectorStyler 1.2.022 release notes
- Fixed an issue with the brush direction on single segment path.
- Convert repeater to curves before expanding.
- Fixed an issue in exporting gradient on stroke to PDF.
- Fixed a bug when changing color of text inside a repeater.
- Transforming a set of node should not transform control points outside of the selection.
- Scaling objects inside transformed layers.
- Improved paragraph style creation and handling.
- Improved support of OpenType/CFF fonts for PDF exporting.
- Links panel improvements to support image replacement.
- Pasting and importing empty paths from SVG.
- Converting color fonts to curves should handle the current color of the text correctly.
- Fixed an output color profile bug in PDF/X.
- Configurable save button sensitivity.
- Shape blending mode should position the shapes correctly.
- Added a blend split function to the blend editor (with double click).
- Import file content when pasting file names (on Mac).
and .23?
@Ingolf There is a regression, still working on it.
@VectorStyler said in update 1.2.022:
But I was offered .23 for macOS and installed it.
@Ingolf Yes, that should work, the regression was fixed in 023
There was a regression in 1.2.022 that is fixed in 1.2.023
Great - I'm not sure which regression, though.
