update 1.2.020
    VectorStyler 1.2.020 release notes
    • Added PSD file exporting.
    • Added PDF/X file exporting.
    • Changing font with text containing style links.
    • Blend object with transformed stroke to handle stroke transformations correctly.
    • Improved performance of Knife and Eraser tools with complex paths.
    • Creating adjustment layers did not select image effect options.
    • Selecting image effect asks in modal view should not reset the effect options.
    • Fixed a bug when duplicating text frames inside groups.
    • Creating artboard guidelines for multiple artboards.
    • Symmetrigon side shape selection.
    • Grid repeater rotation to handle backdrop correctly.
    • Additional Layers panel options for simplifying panel content.
    • Fixed a bug in selecting similar stroke styles.
    • Additional spiral shape options.
    • Gradient export to AI compatible PDF files.
    • Improved performance of repeater with blended shapes.
    • Improved simplify path.
    • Added a new action and shortcut to delete segments between selected nodes.
    • Allow node editing of selected but hidden shapes.
    • Improved text on path dragging when moving to another shape.
    • Added Path panel options to set the distance and angle of two selected nodes.
  • @VectorStyler Great updates! I appreciate it
