Integrated menu
In the Edit - Properties menu of VS, there are many options, such as shape, appearance, and style... But there is no way to paste the properties of the object's width and height. I hope to add this feature. In addition, some of the operation contents inside are redundant. Inkscape has similar operations, but it only needs to copy the object at the same time to obtain all the properties of the object, including color information, width and height, and path effects... It is also integrated. I hope VS will be more user-friendly and simplify the process.
@monsterfox I will try to improve this in the future. The width/height/size can be copied form an object using the Alignment panel by enabling the Align Sizes mode from the panel menu.
I don't know if it will be helpful in your case.
You can record Actions to copy the size from one object
to another object.
You can also assign shortcuts to actions.
@Subpath You have a great plan, too. Thank you for your help.
