Fibonacci sequence and golden ratio?
Would it be possible to add an option for fibonacci sequence and golden ratio grid? For example, drawing rectangles that contain them and adapt when the dimensions of the rectangles change? I use the "Goldie" app as an overlay.
@creative said in Fibronacci sequence and golden ratio?:
Not yet clear how would this work. Would it be a rectangle split into a grid?
@VectorStyler said in Fibronacci sequence and golden ratio?:
Rectangles that are already subdivided by the golden ratio or fibonacci sequence lines.
Perhaps an golden ratio option when creating grids or in the guidelines panel would be the simplest solution.
@creative said in Fibonacci sequence and golden ratio?:
Not sure if this would work as a guideline. Guidelines extend beyond the view, and splitting an area by a golden ration would just create a lot of extra guidelines.
I will have to think this over to better understand it how it would work.
Is there an app where this is implemented, as an inspiration ?
@VectorStyler There are two apps the old Phimatrix Pro and the newer mac app store app Goldie, both can create several grids but work only as an overlay. It would be very handy to have something like this in VectorStyler that would allow more precise work without all the math and magnetic alignment. And there is the golden ratio crop grid in photoshop.
